4B sst2 1v/2v
0 Members and 1 Guest are viewing this topic. Read 1750 times.
vengky
4B sst2 1v/2v
« on: 13 Aug 2010, 02:17 am »
Hi
I noticed that my new sst2 no longer has 1v/2v switches instead its 23dB/29dB. I think its the same thing or is there a difference, not mere label changes?
cheers
vk
srb
Re: 4B sst2 1v/2v
« Reply #1 on: 13 Aug 2010, 02:37 am »
Same thing.  Label change.
BrysTony
Re: 4B sst2 1v/2v
« Reply #2 on: 13 Aug 2010, 02:38 am »
According to the owners manual the 1V setting provides 29db gain and the 2V setting provides a gain of 23db.  So it looks like it is just a label change and I think it is a better description of the switch option.
Tony
vegasdave
Re: 4B sst2 1v/2v
« Reply #3 on: 14 Aug 2010, 03:44 am »
Sounds good.
Mag
Re: 4B sst2 1v/2v
« Reply #4 on: 17 Aug 2010, 02:52 pm »
My ST is set for unbalanced, which setting corresponds to that on the SST/2? :scratch:
Mag
Re: 4B sst2 1v/2v
« Reply #5 on: 18 Aug 2010, 06:18 pm »
Okay, it appears that I had my SST2 set at 2 volts instead of 1. :duh: My other amps were set at 1 volt. I may switch the SST2 back to 1 as I got use to having the surrounds 6 db louder than the fronts.
This also seems to be the reason I was getting slightly boomy bass in Pure Direct 2 channel stereo mode. :oops: :roll:
Having said that, I still prefer MC stereo with enhancer over Pure Direct 2 channel. The bass is more articulate & highs marginally more linear. 8)
