Phonoclone
0 Members and 1 Guest are viewing this topic. Read 2218 times.
Russtafarian
  • Typical reaction to the music I play
Phonoclone
« on: 3 Aug 2010, 04:47 am »
Hey Chair Guy,
Check it out: www.phonoclone.com
I used the latest V3 boards.  It's up and running using a SLA battery power supply.
Next time you're in SoCal you're welcome to come by for a listen.
Russ
Sonny
Re: Phonoclone
« Reply #1 on: 3 Aug 2010, 05:00 am »
Russ you lucky guy...new DAC Huh?!!!! :thumb:
TheChairGuy
Re: Phonoclone
« Reply #2 on: 3 Aug 2010, 02:41 pm »
Hey Russ .... yeah, I checked out the site Saturday morning.
It's a pretty spartan site, so finding the right phono stage you were mentioning was EZ :thumb:
How's it sounding with all that delightful overkill power supply? :wink:
Thanks, John
Russtafarian
Re: Phonoclone
« Reply #3 on: 3 Aug 2010, 11:52 pm »
@Sonny:  No DAC, just dock.  The Wadia dock extracts SP-DIF from an Ipod.  It will probably end up plugged into the HT receiver.  My boys will dig that. Ipod soundtrack to Xbox games on the Home Theater.  Boys= :thumb: Dad= :duh:
@John: The clone is sounding very nice with the DL103.  Still playing with cartridge loading but a definite step up in resolution and extension compared to the older Audio Research single 6DJ8 stage I was using.
If I could have found 18v 500 mHA rechargables, the battery PS would have been a lot simpler.  On the other hand, I should be able to get about 500 sides between charges  :o.
