Bryston BP-26 output: balanced more gain. Would I be better off using unbalanced
0 Members and 1 Guest are viewing this topic. Read 3069 times.
Elizabeth
Mainly for James Tanner:
I was reading all the old Bryston Circle posts here, and ran across the fact that the balanced output of the BP-26 is much higher than the unbalanced output.
IF I used the unbalanced output, would I (without having to send in my amp for pro model attenuator) be able to have less gain from BP-26, and thus use more of the volume control range?
I would just try it, BUT my current pre to amp distance is 20 ft, and I only have a balanced cable that long.
I have no problem with the loss of balanced common mode noise rejection IF I went to a non-balanced cable.
(In fact i would probably just swap connectors on the cable I now use (Kimber Hero)
So I am just wondering?
(I am waffling on sending in my 4B-SST2 for the attenuation thing just because of the old warning:"If it ain't broke, don't FIX it"
  • The Demo is Everything!
    • http://www.bryston.com
Hi Elizabeth - yes using the single ended RCA will 'reduce' the gain by 6dB (assuming the same 1v or 2 volt setting on the sensitivity switch).
james
Elizabeth
Cool. I will have to find a cable to try it out.
Thanks again.
Thanks again.
Elizabeth see if you can find a pair of XLR to RCA adapters and try it on your existing xlr cables.
james
KnowTalent
  • ...stuck in the middle with you
forgive me for nosing in here but volume attenuation generally attenuates the input signal not the output signal therefore I am confused with your line of reasoning on this?  I could be wrong so if the BP26 vol control does attenuate the output then please let me know :thumb:
If you wish to experiment wouldn't it make more sense to instead run the output of your BDA/BCD unbalanced to the BP26 input?
Elizabeth
Sorry Knowtalent, you are not getting the picture. I am not going to go into the whole thing. suffice to say you are on the wrong page.
KnowTalent
:thumb:
