0 Members and 1 Guest are viewing this topic. Read 48150 times.
Thanks Mr EdWill peruse this site, which I had not realised even existed, when I get the time.It will be interesting to see what others have done, not just in terms of component values, but also regarding use of active versus passive solutions.CheersLuigi
Hi Luigi ~I am currently using a re-designed Heathkit amplifier (circa 1950) using EL-84 tubes in Triode configuration... 8 potent watts (it has the pre-amplifier built in) with treble and bass controls... bless Sam Kim... to drive the B200's and Alpha 15's joined together with a simple cheap copper coil inductor with a value of .80 for the Alpha's... the B200's run full-range. Believe me... it quite enough to release all of the musical potential those 2 drivers can deliver. Potent 3-D, holographic, room-filling, dynamic, musically alive sound.I even was able to run these speakers with a 2.5 watt 45 SET amplifier with a "passive" preamp... and the sound was quite satisfying... modest levels to be sure... but sublime where it played.I will probably be unpopular if I say that the right tube amplifier... preferably triode-based (not necessarily Single Ended... this one is not) will bring out the full potential of this driver combination. At least that is my experience... and the subjective factor of audio must be considered... simply because it recontextualizes everything brought into play in the service of the music.The steep rise in the B200's, noted by many intelligent sensitive listeners who write their insights on Audiocircle, does not appear in my system. Cheap, "universal" CD player, cheap wire, cheap crossover... simple... the music is glorious.But... and here everything becomes a bit strange, admittedly... one needs a synergistically sympathetic amplifier... preferably tubes... to realize the full potential of this driver combination in OB's.Please let us know how things unfold for you, Luigi. Thanks for sharing your insights.With Warmest Regards ~ Richard
Richard, are you running one or two Alpha 15s per speaker? Also, what is the effect of the .8mh coil? is that a low pass? thanks
I believe he is using one Alpha per baffle.The .8 mH inductor (low pass) should start rolling the 15 out at @ 1500 hz, but a quick glance at the graph on this page will tell you otherwise.http://www.parts-express.com/pdf/290-407s.pdf Lin
