Any thoughts on these speakers?
0 Members and 1 Guest are viewing this topic. Read 10300 times.
jackman
« on: 27 Jul 2010, 09:05 pm »
I'm looking for something inexpensive for my office. Must be very small, inexpensive and fit on a small shelf or on wall.  Not concerned about audiophile quality at this point but must be able to play loud (once in a while).  I've got a small sub so I don't care about deep bass.  Need something narrow and now too deep.
What do you guys think about these?  Kind've futuristic looking.
http://www.vanns.com/shop/servlet/item/features/542699643?v_c=em-072410-48AudioSale
Atlplasma
  • Just off the boat
Re: Any thoughts on these speakers?
« Reply #1 on: 27 Jul 2010, 09:13 pm »
You might also want to consider these Hsu speakers. They are about the same price.
http://www.hsuresearch.com/products/hb-1.html
jackman
« Reply #2 on: 27 Jul 2010, 09:51 pm »
I think that Hsu pricing is per speaker.  These are $179 for the pair, shipped.  Not saying it's a better deal but I'm looking for something inexpensive and compact to play around with in my office.
Mariusz
« Reply #3 on: 27 Jul 2010, 10:36 pm »
If you do not mind some diy and its size, I would recommend these curved .25 liter enclosure from parts express (on sale $125 with coupon) and your choice of drivers - Fostex 126 and Jordan drivers sounded pretty good in those boxes.
http://twitpic.com/1v6qxz
If you use Fostex drivers - low power amp -3 to 20wpc- would be enough. Planty choices on the cheap side of spectrum.
If you want to invest some more, Jordans would fit the bill perfectly. You would need a bit more muscle tho. Virtue or DIY Class-D amp would be perfect.
Mariusz
saisunil
« Reply #4 on: 27 Jul 2010, 10:43 pm »
Looks like a real good deal to me -- how they sound? that's a different question ...
Kevin Haskins
« Reply #5 on: 27 Jul 2010, 11:02 pm »
They look like something from a Pixar movie.
ebag4
« Reply #6 on: 27 Jul 2010, 11:37 pm »
This may be too small for your application but I have read a couple of positive mentions of this unit here on AC.  I seem to recall Laura (Vinyl Lady 1) and jwtrace(?) mentioning how good this unit is.
http://www.amazon.com/s/?ie=UTF8&keywords=foxl&tag=googhydr-20&index=aps&hvadid=3997397905&ref=pd_sl_82lleo3den_b
Best,
Ed
Atlplasma
  • Just off the boat
« Reply #7 on: 27 Jul 2010, 11:50 pm »
Sorry. I posted without thinking.  :oops: You might want to check out Audiogon or even your local Craig's List for more bang for the buck.
eclein
« Reply #8 on: 28 Jul 2010, 12:12 am »
+1 on CL..thats where I got mine for almost nothing
Doublej
« Reply #9 on: 28 Jul 2010, 01:14 am »
Are you sure they are $179 for the pair? The linked page says "speakers priced and sold individually"
I have an earlier version of these Teac LS-H100 speakers hooked up to my computer via an old Pioneer integrated amplifier using single strands of cat 5 network cable as speaker wires. Sounds darn good to me. I opened them up and was amazed at how complex the crossover was.
Unfortunately Overstock is showing them as out of stock at the moment.
http://www.overstock.com/Electronics/Teac-Book-Shelf-Wood-Trim-Speakers/2929384/product.html?AID=10654383&PID=1796839&SID=6080622
www.orangechimp.com has some other small Teac speakers for under $40/pair including a LS-H300.
dvenardos
srb
« Reply #11 on: 28 Jul 2010, 05:27 am »
How about a pair of Jamo C401 on closeout from Vann's for $80/pair shipped.  Although in the reviews, many were replacing and comparing to their Sony, Bose, multimedia and HTIB speakers, a number of others compared them to smaller B&W, Paradigm and Epos.
http://www.vanns.com/shop/servlet/item/features/542471827/jamo-c401
You didn't say what you are powering them with; these are 6 ohm, 86dB.  Dimensions: 5.7" W x 9.3" H x 8.3" D
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #12 on: 28 Jul 2010, 05:52 am »
Mariusz,
You mean the 7 litre box? FE126 gets down to 125 Hz in it. A better all round performer in this box is the Mark Audio CHR-70 Mk2. Madisound now has them at an obscenely low price. For near field use 5-20w is recommended.
(note that despite what they say CHR & A7 are nominal 4" and A12 is nominal 6.5")
dave
Mariusz
« Reply #13 on: 28 Jul 2010, 06:20 am »
Mariusz,
dave
Thanks Dave
Around $70 a pair is tempting and I might try it out to see how it does in this enclosure.
You're right - it is 0.25 ft³ not liter.
 :thumb:
Mariusz
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #14 on: 29 Jul 2010, 07:18 am »
They respond well to being souped up too...
dave
Mariusz
« Reply #15 on: 29 Jul 2010, 08:10 am »
I need one of those magician's hats
Nice work Dave
Wish I could do it on all of my drivers.......just for fun that is.
As to decent sounding and not too expensive monitors ideas..... here is what I use in my bedroom:
cabs sells for $149 a pair ( cheaper if you got saving coupons), drivers - Fostex I bought used here for  :scratch: not 100% sure...$60 or close to it. Jordans are more expensive but as David said,.... you can use those $70 Mark Audio drivers.
Certainly worth trying but you might also check out Tekton offerings. Word of the mouth is, that those are great little speakers that won't break a bank.
Mariusz :thumb:
or these
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #16 on: 29 Jul 2010, 03:22 pm »
Check out Stew Nelles' latest "from the Pulpit" Page 28 of the latest AffordableAudio mag. (he has the older, CHR70 Mk1)
dave
silver_strings
« Reply #17 on: 29 Jul 2010, 10:56 pm »
I would also go with some single drivers paired with a small amp, check out the tekton 3.1s, these wont play super loud though but they can get to loud for a small room
stigs
« Reply #18 on: 4 Aug 2010, 03:27 pm »
I concur with SRB regarding the JAMO C410 as I own a pair myself purchased through Vann's and they sound great.
bundee1
« Reply #19 on: 4 Aug 2010, 03:51 pm »
What are you powering the Jamos with?
