Any thoughts on these speakers?
0 Members and 1 Guest are viewing this topic. Read 10302 times.
Bemopti123
Re: Any thoughts on these speakers?
« Reply #20 on: 4 Aug 2010, 04:41 pm »
This may be too small for your application but I have read a couple of positive mentions of this unit here on AC.  I seem to recall Laura (Vinyl Lady 1) and jwtrace(?) mentioning how good this unit is.
http://www.amazon.com/s/?ie=UTF8&keywords=foxl&tag=googhydr-20&index=aps&hvadid=3997397905&ref=pd_sl_82lleo3den_b
Best,
Ed
I own one of the earlier models.  Sound quality is fine for what it is, but you need to be extremely carefully while handling the unit....if it falls or it hits a hard surface, you will crumple the metal grill easily...and everything will sound distorted, which has to do with the function of the neo drivers being spherical, with a hair breath space of the grill....The disassembly of the unit is tough as they have put some sort of glue that makes it a dog to dislodge the screws.
All being said, perhaps it would be better to have a conventional, efficient speaker+ affordable amplification.
