0 Members and 1 Guest are viewing this topic. Read 33457 times.
"Class D" refers to how much of the 360 degree cycle the amp device is biased on. Class D pumps out tons of power with little heat compared to class A/B.
http://www.audiocircle.com/index.php?topic=76400.0
Q: So what class D amps are considered audiophile grade-and what makes them different from the hard sounding PA amps? Or is this issue related to a PREAMP more than power amp section? All inputs appreciated!
Class D amplifiers use a high frequency digitally controlled switching circuit, often Pulse Wave Modulation, to modulate the analog wave. Since the output devices are either on or off, there would theoretically be no bias current. The link above is to a topic on DIY ampflier modules by a company called "Class D Audio", who use either International Rectifier or Yamaha IC's to control the switching of FET output devices. They also sell linear power supplies for use with the amplifier boards. There are some manufacturers that utilize their own proprietary class D circuits, such as NuForce, but the majority use modules from Hypex (UcD) or Bang & Olufson (ICEpower). Some manufacturers use the modules in stock form, while others do their own modifications, often to the input stage. Channel Islands Audio uses modified Hypex UcD modules, while Bel Canto, Jeff Roland, Rotel, Virtue Audio (ICEBlock M5001) and Wyred 4 Sound use the B&O ICEpower modules. There are economy as well as higher-end modules available, and the use of the higher-end modules along with proprietary modifications can differentiate themselves as "audiophile grade". I haven't seen class D employed in preamplification (it's possible it exists somewhere), and the general application is for power amplifiers. Steve
Please keep this post going cause I am interested in class D but not into DIY at all. From what I have read in other threads, They talk about a lot of stuff that I have no idea what their talking about, or what chips do what or or or I get so confused, I want my Mommy!
The class D ampllifier's frequency response tends to be more dependent on the speaker load, so synergy with your speakers is important.
This is a generalization that has nothing to do with class-D topology. The Hypex modules, for example, are completely load insensitive.
Am I right in assuming that the amps sold by Digital Amplifier Company like the DAC4800 and Cherry amps are in the upper end of Class D amps?
but more from left to right (more width than depth). Instruments have plenty of room around themselves and vocals are very clean and clear.
There is no such thing as "completely load insensitive"...Also, it takes wrapping feedback around the output filter to REDUCE load dependence, and in our experience, this affects the sonic quality of the amp in a negative way --- no pun intended.
Read the AES white-papers published by Bruno Putzeys, if you haven't alread done so. IMO (and a lot of others) he's the undisputed expert in the field of class-D amplifier design. He also happens to build the best sounding class-D amplifiers, IMHO.
