0 Members and 1 Guest are viewing this topic. Read 34409 times.
So if I spent $1,200 on an A, A/B and would like to find an equivalent or better, Should there not be a class D that would fit the bill for less. I am going to look up the Wyred amp but can anyone make any other suggestions? Present amp is delivering 140X4 into 8 and 225x4 into 4.ThanksDon
Class d: less parts, same cost as class ab. Why?
$299 non-DIY class-d amplifier. They may or may not be using Coldamp modules. Enjoy.
Neutrik Speakon outputs with both XLR and 1/4" inputs. The amp is targeted, but not limited to, the pro market. Most of these will live in a rack; thus the fan.
Which brings back my unanswered question about crown. Crown made the macro reference at one point that wowed the critics. They have a variety of class d amps now. Assuming that I built proper cabling, wouldn't these $399 amps work for high fidelity? If not---why not?
It all depends on what YOU consider high fidelity...
The discontinued panasonic sa-xr45,55,57,70,700 are low cost class d. probably nothing available now that compares for the price.
I'm afraid nobody who hasn't listened to one in their system is going to be able to answer that question for you. Why not buy one from a dealer with a good return policy and send it back if you don't like it? I have no reason to suspect the class-D Crown would sound poor given that the current crop of switching amplifiers that I've heard sound pretty good overall.
Ok simple question. Crown has class D stereo amps for $399. What would make them fall short?
