Sealed Type N3 Building
0 Members and 1 Guest are viewing this topic. Read 16944 times.
hotjt133
Re: Sealed Type N3 Building
« Reply #60 on: 28 Feb 2011, 12:43 am »
Groundzero,
When I Veneered my N3 TL's I did run out of Heatlock...the bottle that I had (1 pint?) wasn't quite enough.  I finished my N3 project using Titebond II with the same iron-on method.  To be honest I didn't notice a significant difference between using the Heatbond and the Titebond II. :wink:
Pete
I'm wondering how big is surface area of a pair of N3 TL? It should be much less than a sheet of 4'x8'. Do you apply multiple coats on each surface?
From this page http://www.betterbond.com/heatlock/heatlock-FAQ.htm it says "A pint size bottle of Heat Lock will cover approximately 45 square feet of veneer."
Ron
« Reply #61 on: 28 Feb 2011, 01:03 am »
 Since you are applying glue to both the back side of the veneer and the cabinet surface you need close to three (3) pints to veneer a pair of N3 TL's. I purchased a gallon jug of the Heat Lock glue which was a lot cheaper than buying the smaller size bottles. The Titlebond II works well too.
Groundzero
« Reply #62 on: 2 Mar 2011, 08:27 am »
Hey Ron,
I have a quick question about the Neo 3 hole for a future build of mine. For the tweeter countersinking and hole the plans call for 5.11" and 4.3". Did you somehow make those exact sizes or use the closest fraction of an inch? The circle jig I have can do 1/16" increments so I was thinking of 5-1/8" and 4-5/16" (5.125 and 4.3125.) Would that be okay?
Kristian
Ron
« Reply #63 on: 2 Mar 2011, 11:02 am »
Hi Kristian,
 I used a Jasper circle cutting jig on my router to cut the holes. Made the outter hole 5-1/8" and the inner hole 4-5/16". They worked just fine for me.
Ron
Danny Richie
« Reply #64 on: 2 Mar 2011, 01:55 pm »
The tweeter measurements were made with a dial caliper.
Try a few test cuts and see how close you get with your jig. I have found that I can rotate my Jasper jig on my router and get it to move one way or another by about 1/32 of an inch.
So with a little effort you'll find a setting on your router that will nail the size.
NeilT
« Reply #65 on: 2 Mar 2011, 07:19 pm »
« Last Edit: 2 Mar 2011, 11:32 pm by NeilT »
Rclark
« Reply #66 on: 23 Apr 2011, 04:40 pm »
Is the crossover in this one the same? Thinking of having both the sealed and TL version to try.
Danny Richie
« Reply #67 on: 23 Apr 2011, 04:43 pm »
Yep.
