0 Members and 1 Guest are viewing this topic. Read 1855 times.
I'm using the Silver Eclipse 6 balanced IC's from CD>BP26>7B SST2's as well as the Silver Eclipse 6 SC's. They made a very noticeable improvement on my previous cables (Monster). I'm very pleased with the sound. One caveat on the WW SC's is they are flat (45mm wide) and can be a little cumbersome to work with in tight spaces. Not enough to be a deal killer, however. I spoke with David Salz the president who tells me that Bryston uses WW cables frequently in show setups. Don't know which ones, however. Their customer service is great. I bought them with bananas and decided I would rather have the spades after using them for a few days and they had me send them back, installed the spades and had my cables back to me in the same week at no additional charge. Give the manufacturer a shout, you just might get a response from the president.
Please pardon this most brief interlude…Bill,Why do you prefer the spades over the banana plugs? I use banana plugs and I am wondering if I might be missing out on something with respect to this.Be well…
Hi Andy,Strictly physical reasons. As I mentioned the flat SC's and the inflexible egress route at the back of my cabinet requires a more secure connection than the WW bananas were providing. I had one or two plugs collapse in rendering the connection completely loose. The spades are working great. I don't buy in to any argument that says one is superior sonically over the other.Ciao!
