0 Members and 1 Guest are viewing this topic. Read 2991 times.
It doesn't have any bass management like most of the preamps. Get an extra pair of outputs, and connect it to your sub.
Well, mine goes down only to ~90Hz ... and i have the same problem. Talk to klaus and see if he can whip up something special for you. I'd love to have a preamp that does bass management. Or else, get a behringer or marchand active crossover, and that should solve your issue.
FWIW, I had the second set of outs installed and send it to a sub. Then use the crossover and volume on the sub to dial it in by ear. I have martin Logan Ascent i's and a Velodyne SPL1200 which is set at about 80 hz, I think. Works for me, but YMMV.
