0 Members and 1 Guest are viewing this topic. Read 4834 times.
"Paul, I am absolutely amazed. I got the Anti-Cables today. Brand new, out of the box, they outperform my Kimber 8tc's, MIT Terminator 2's, Audioquest Slates, and Audioquest Bedrocks by so far, it is almost an immeasurable difference. Who did you have to sell your soul to, in order to come up with this so simple, but perfect design. I can't wait to listen to the improvements (if possible) as they break in. This is the most remarkable, yet affordable change I have ever made to my system. No matter what I change in the future, your Anti-Cables will be first and foremost, the key to the ultimate performance. I must admit I had my doubt's, but I am now ready to sell my soul, for more of your products. Thank you very much for your devotion to the best reproduction of music possible. A customer for life."
I believe an Ultravalve is $1600 roughly, and the HT2-TL's start at $4k.
Jim - Will an Ultravalve work pretty well with HT2-TL's? Judging by the number of HT2 owners on the forums, I would think this would be one of the more popular pairings if the power level is appropriate.
True, but if he upgraded the amp and preamp we're talking $3k+. The upgrade to HT2-TLs would only cost ~$2600 if he were to sell his Songtowers.
You might ask why 35 tube watts are sufficient, but 35 solid state watts are not enough to drive the SongTowers. The reason is the soft clipping nature of tubes.Solid state amplification is very linear up to its maximum output. If instantaneous transients drive solid state past its maximum output, it clips hard. It basically hits a brick wall and the resulting clipping will sound harsh and brittle.Tubes, on the other hand, are linear to a point and then the gain begins to fall off. So when the input drives the amp toward its maximum output, it simply provides less gain. It acts very much like an audio compressor - it is linear to a point and then simply rolls off, supplying less gain.This is often referred to as "soft clipping" and is far less objectionable than "hard" solid state clipping. The result is what some people would call silky smooth, warm and musical performance.- Jim
John, out of selfish curiousity, if you or anybody else here is looking for a little somethin' - somethin' to further tweak his system, I would love to know what an inexpensive cable called Anti-Cables would do for your sound. They are about $10 a foot. Here's one of dozens of testimonials from http://www.anticables.comAbsolute Sound also had a very favourable blurb on them.If such inexpensive components do make such a notable difference in some systems I think it is worth knowing. I would like to know if Jim or Dennis of Frank have noticed appreciable differences between cables, given the revealing nature of the Salks.Mark
Yes I know. I think he's wondering about the tube sound. Sure, he could skip the hybrid pre and the tube amp, and get HT2-TL's. But an HT2-TL, while a wonderful speaker, isn't going to have a tube sound to it and he's still out 3k. And in particular, the supreme musicality of the Ultravalve we keep hearing about is probably sticking there in his mind too Certainly if he was looking to overhaul his system, HT2-TL's are a great speaker. But I think he's really looking to experiment with a tube sound and/or modify the front end rather than get rid of the SongTowers (which are great as well).
If you just want to "try" an Ultravalve, don't worry about making us unhappy if you return it. However, if you are sure it is just for a temporary tryout, we will supply one of my first generation prototypes that we won't mind if it gets a scuff or minor ding. If you want to keep it, fine, or then you can exchange it for a brand new shiny one at no extra cost except for shipping.
