Ribbon Replacement for RM-30 (Kids and shiny things...)
0 Members and 1 Guest are viewing this topic. Read 2193 times.
rickkuy
I made the disturbing discovery that the FST tweeter ribbons in my RM-30's had mysteriously been mashed in following a gathering of young kids at my house.
It's my understanding that the ribbons can be replaced without replacing the entire tweeter. I'm wondering if anyone has experience replacing the ribbons, and if so-- please share any do's and don'ts.
Mine are the de-horned version-- I gather these are derived from the Aurum Cantus G2Si's? If so, Parts Express has a replacement ribbon, part#274-401. The only complaint the reviewers had is that the replacement comes with no instructions, so I'm wondering if this is a very delicate operation?
Any help is much appreciated-- my tweeterless RM-30's sound just a tad lifeless!
--Rick.
soarertoy
Re: Ribbon Replacement for RM-30 (Kids and shiny things...)
« Reply #1 on: 6 Jul 2010, 03:38 am »
Hi,
Yes, Parts Express sent me replacement ribbons, p/n 276-403 for the RM2 G2's, nicely crushed flat with bubblewrap into the bottom of a plastic container - twice!
I eventually successfully bought from Creativesound in Canada tel 1 604 504 3954.  They were also able to supply metal faceplates for the Aurum Canti, with a protective mesh (no more little fingers), to replace the black tar stickers.
Cheers
Richard
E-speakers are also Aurum Cantus reps.
rickkuy
« Reply #2 on: 7 Jul 2010, 04:36 am »
Thanks Richard--  I'll give Creativesound a shot. Is installation pretty straightforward?
soarertoy
« Reply #3 on: 7 Jul 2010, 05:17 am »
Yes, just unstick then unscrew bits till the old ribbon is removed, then replace.  No need to unsolder the drive unit leads.  Try to avoid the (nicely corrugated) ribbon rubbing the sides of the slot.
Phone me on 250 294 5790 with any questions.
Cheers
Richard
soarertoy
« Reply #4 on: 8 Jul 2010, 04:01 am »
I see the Aurum Cantus site now has ribbon fitting instructions - http://www.aurumcantus.com/aurumcantus-download/pdf/Repair%20Instructions%20for%20ribbons.pdf
Cheers
Richard
rickkuy
« Reply #5 on: 8 Jul 2010, 05:08 am »
Very cool Richard-- thanks for the link to the instructions.
Creativesound is out of the ribbons, however they did say they'd send tweeter faceplates for the cost of postage. They suggested Parts Express for the ribbon.
I'll check with E-speakers first, then go with Parts Express if I have to.
Thanks again, the help is much appreciated.
--Rick.
