I just built a bugle!
0 Members and 1 Guest are viewing this topic. Read 2086 times.
harryf
« on: 12 Jun 2010, 10:22 pm »
Ok i have been haveing a hum issue with my cornet 2.So i also had bought the bugle board awile back to use with my fisher 500c.I thought why not spend a afternoon and try the bugle out to see if i could get hum free lp play.Well i just finished.Wow!what a value!!!It's silent and sound's great too.
I learned something too as i only had left over cap's to use for this project.The thing flat out sound's amazing for what it cost's.Usually i use auricap's
Does anyone know of a on off switch that could be chassis mounted and used instead of the stock switch?
I made mine in a hammond aluminium case that i had used for my old cornet 2.I want a on off switch for the front.It's the 6 prong's on the stock peice that's throwing me off.I have a on off switch i could use but it does not have 6 prongs.I has 3 i think?
Sonny
Re: I just built a bugle!
« Reply #1 on: 12 Jun 2010, 10:38 pm »
Cool, post some pictures!  I use the Bugle's power supply for my DIY Curcio designed RIAA phono...
T
dangerbird
« Reply #2 on: 13 Jun 2010, 12:05 am »
Wow,, very nice work sir.  :thumb:
GRD
« Reply #3 on: 13 Jun 2010, 02:48 am »
Is the Curico gain set for MM or MC gain, and how does it sound?
Sonny
« Reply #4 on: 13 Jun 2010, 07:01 am »
I think the Curcio sounds amazing!  I've had the Jolida phono, the Musical Surrounding, and a Diva audio tube as well as the Odyssey Tempest phono, and I think it sounds best of them all!  It's very detailed and full bodied, not warm but very musical!  I love it!  A friend is working on a board for it and it may / could become a production run of sort...
If you're in the Bay Area, let me know...I can have you over or anyone else...
Tuan
etcarroll
« Reply #5 on: 13 Jun 2010, 03:31 pm »
So is that the 'Sarah' Curico with the Bugle power section?
What tubes in the Curico?
Gene
david62
« Reply #6 on: 14 Jun 2010, 12:57 pm »
Beautiful work.Enjoy.
Dave
Sonny
« Reply #7 on: 14 Jun 2010, 01:55 pm »
Gene
No, it's not the "Sarah", it's the RIAA Phono Pre - Passive/Active EQ designed by Curcio for use with the National Semi Conductor chips LM49710.  A good friend found the design, built it first and I liked it so much he help me build one for myself!
NO TUBES...
Here's a pic of the inside:
