**SOLD**SB3 with Standard power supply $155 shipped
0 Members and 1 Guest are viewing this topic. Read 1521 times.
Big Red Machine
I have a silver faced SB3 that is WIRED ONLY with remote and power supply.  This unit works fine with ethernet cable into your network and the remote works - it just cannot receive a signal wirelessly from a router for instance.
Killer deal at $155.
Shipping extra is free to CONUS buyers.
« Last Edit: 14 Jun 2010, 12:41 am by Big Red Machine »
Big Red Machine
Re: SB3 with Elpac power supply
« Reply #1 on: 8 Jun 2010, 01:38 am »
« Last Edit: 10 Jun 2010, 10:07 pm by Big Red Machine »
Big Red Machine
« Reply #2 on: 9 Jun 2010, 03:13 pm »
Apparently not the bargain I thought so I adjusted the shipping.
kgturner
« Reply #3 on: 9 Jun 2010, 03:35 pm »
i'm partially interested in the elpac for my touch. that sb3 looks oddly familiar though....;)
kevin t
Big Red Machine
« Reply #4 on: 9 Jun 2010, 04:07 pm »
I have another Elpac.  What is the voltage for the Touch?  I thought it was different than the SB.  I believe the SB is 5 volts.
kgturner
« Reply #5 on: 9 Jun 2010, 04:17 pm »
i believe wayne said that the elpac would work with the touch as long as you don't try running an external unpowered hard drive, which i don't. now that i think about it though, the barrel connectors on the sb3 vs. the touch are different so wayne would likely need to mod it. i was hoping for plug and play. i'll shoot wayne and email to find out what's what.
kevin t
Big Red Machine
« Reply #6 on: 9 Jun 2010, 04:25 pm »
If it works, snip the connector off the end and I'll solder it on for you.
kgturner
« Reply #7 on: 9 Jun 2010, 06:59 pm »
wayne says that the elpac will work. still trying to get clarification on the dc connector. i'd prefer to leave the touch's wall wart alone and just put a new connector on the elpac. does your elpac have the appropriate dc connector or will one be needed? before we delve much deeper, how much are you wanting for the elpac?
kevin t
Big Red Machine
« Reply #8 on: 9 Jun 2010, 07:23 pm »
Oh geeze, I thought cost was no object!   :o
My Elpac has the SB connector on it as I had some lying around from my old R/C days (same as the charger cords for radios).  The connector was talked about in the threads months ago.
$40 because it's you!
kgturner
« Reply #9 on: 9 Jun 2010, 07:46 pm »
sounds reasonable to me. split shipping to 36695?
Big Red Machine
Re: SB3 with Standard power supply $155 shipped
« Reply #10 on: 10 Jun 2010, 10:07 pm »
updated to SB3 with std ps and lower price.
