Where do you get fuses?
0 Members and 1 Guest are viewing this topic. Read 3472 times.
mdfoy
« on: 5 Jun 2010, 01:11 pm »
Where do you get 5X20mm 6.3A 250V fuses for your Khartago?
golfugh
  • Dead Can Dance - Into the Labyrinth
decal
Re: Where do you get fuses?
« Reply #2 on: 5 Jun 2010, 01:26 pm »
radio shack
mdfoy
« Reply #3 on: 5 Jun 2010, 04:01 pm »
All,
Thanks for the responses.  Does any one know how to get a stripped screw out.  One of the Khartago screws is stripped, and I can't get it out.
timind
  • permanent vacation
« Reply #4 on: 5 Jun 2010, 04:19 pm »
Is the screw cross threaded (hard to turn) or is the head stripped?
mdfoy
« Reply #5 on: 5 Jun 2010, 04:40 pm »
The head is stripped.  I can't move it pliers either, they don't get a good grip.
mdfoy
« Reply #7 on: 6 Jun 2010, 01:40 pm »
decal,
Thanks for the input, but this didn't work either.  The screw is screwed. :banghead:
decal
« Reply #8 on: 6 Jun 2010, 03:13 pm »
decal,
In that case,you'll probably have to drill it out then retap the hole.
Speedskater
  • Kevin
« Reply #9 on: 6 Jun 2010, 04:13 pm »
My friend who was a part time camera repairman, fixed my eye glasses by drilling out the small (very small) screw that holds the ear piece on.  The screw came out like a coiled spring.    So in highly skilled hands it's possible.
Jim N.
  • Who you callin' an audiophile?????
« Reply #10 on: 6 Jun 2010, 07:50 pm »
I got ceramic 5x20 6.3A fast blows on EBay that were shipped from Europe. I forget the vendor though.
mdfoy
« Reply #11 on: 8 Jun 2010, 02:18 pm »
Can you use a 5X20mm 6.3A 125V fuse in the Khartago?  I am finding the 250V fuses easy to order, difficult to find readily available. 125V are falling out of the sky. I ordered some 250V from parts-express, but was wondering if the 125V could be used in a pinch.  I still haven't solved the stripped screw head issue. :cuss:
mdfoy
« Reply #12 on: 9 Jun 2010, 11:50 am »
Thanks to all for their suggestions. :bowdown: I got the screw issue solved.  I was able to use a allen key.  A very educational  experience, and a exercise in patience.  After all of that, it was not a blown fuse, but another issue upstream. The high-end.
tgp06
« Reply #13 on: 9 Jun 2010, 12:15 pm »
For future reference regarding removal of a stuck screw with a bad head. One trick is to use a left hand drill bit slightly smaller or approximately equal in diameter to the screw shank turning counterclockwise in a reversible drill. It will often bite into the screw material and back the screw out. Otherwise , try an easy out if you can find one small enough- it still requires you to drill a small hole in the stuck screw, though.
