0 Members and 1 Guest are viewing this topic. Read 20991 times.
Not one to leave well enough alone I bought the priciest and supposedly best grease in the world, Dupont Krytox to see if there was benefit - at $30 per 2 oz you'd hope it would No such luck - to my ears - it did not better the white lithium grease. Again the bearing is super close tolerance, so it seems to mitigate the benefit of lubricant.
I might try some clock oil in the tone arm pivot bearings since the load is so light but unless you're using a very heavy platter [not sure what the VPI weighs John], grease would seem to be excessive and high quality auto engine grade synthetics [different brands here in Aus.] are the go.jules
The platter is really heavy in the VPI Classic...I think some 20lbs (9k or so). So maybe why VPI specifies grease now John
Moly is for extreme pres. applications, and usually heavy and sticky, not the best for a tt IMHO.
Ditto with Tuan and John, I utlize the VPI 'Super Platter' (25 lbs), combine that with a 'perf ring' and your pushing 28 lbs.
