How about some more discussion on cartridge alignment?
0 Members and 1 Guest are viewing this topic. Read 21419 times.
hesson11
Re: How about some more discussion on cartridge alignment?
« Reply #40 on: 1 Jul 2010, 03:45 am »
Bob,
LOL, I accept that you're quoting Keith Howard out of context and maybe he isn't a complete moron. But when I read, "When I laboriously measured my LP collection 30 years ago, I found a significant proportion had minimum radii down to 58mm, which I subsequently recommended as a realistic figure to use in alignment calculations." I gotta wonder...What are you going to do, change the inner null to 58mm? If you change the calculation for the center of grooves to include 58mm as the lead out start, then you'd have to move it (center) in 1.1625mm.
neo
Hi Neo,
Just reporting what I read! In fact, you may find a passage further into the article equally interesting: "For a modulated-groove-radius range of 56-146.3, they (the null points) should be at 61.6 and 118.4mm; or, for 58-146.3mm, at 63.6 and 119.6mm."
I knew you'd want to know!  :D
-Bob
neobop
  • BIRD LIVES
« Reply #41 on: 1 Jul 2010, 11:10 am »
Hmmmmm.....I don't see how my post is so controversial.  Your last sentence above is 100% correct.  That's why I do it that way.
Wayner doesn't agree.  I explain an easy and precise way to align a rounded body cartridge (or any cartridge, for that matter) and his response is that it is BS.  No explanation why it is BS....just that it is BS.    Or maybe the explanation is there, and I simply don't understand it.
he says:
The most critical factor of any cartridge alignment is offset angle, shit they all have to be on the nat's ass, but the fact is, you can't possibly see even 1/2 degree of error with the human eye. Overhang is the easy part of the equation. If you have a cartridge that the stylus is skewed from the body, I'd send it back. If you can see it with your naked eye, there is serious quality control problems with the manufacturer. I don't buy any of this for one minute.
First of all......I am not talking about a skewed stylus, whatever that is.   I specifically and clearly said cantilever.  It is not unusual for them not to be set 100% perfect in the cartridge body.  Hence the reason for aligning the cantilever and not the cartridge body.   If cantilever is off by a small amt,  and you can't see it,  why would you wanna set the offset with the cartridge body?  That method assumes there is no cantilever build error, and if error is present you are 100% guaranteed to obtain an incorrect offset angle!
The Kuzma method I use makes no such assumption.  It only assumes that the stylus is attached properly to the cantilever.  It will yield good offset angle results even if the cantilever is off....by any amt, small or large.  If you sight down the line properly and use a good light and magnifier lens, it really is easy to adjust things such that the line and cantilever blend and become one.   Doesn't this mean that that the offset angle is correct?
Conversely,  there is no such assurance when using cartridge body, if the cantilever is not set 100% perfectly.  So how is using the cartridge body better?   What am I not understanding here, Wayner?
Also,  trying to achieve a cartridge body parallel to grid lines is much harder to see and accomplish than my cantilever / line merge method.  I have done it both ways.  Unless someone can explain otherwise, the cantilever alignment method just makes more sense to me.
The proof is in the pudding.  I always get phenomenal sonic results very quickly when using the Kuzma setup method.   This has not been the case when trying to align the cartridge body with my DB Systems protractor.
Additionally,  and no offense Wayner, but I have much more confidence in a method recommended by Franc Kuzma  -- who in my estimation is a genius in the analog world -- than by you.   I have owned several of his products, all excellent.  I think my current Stogi Reference is an absolutely killer arm......way better than the SME V that I previously owned.   So based on my direct experience with his gear,  I would say he knows his stuff!   :thumb:
Sunnydaze,
Afraid it's not that straightforward. A lot depends on the cart and the internal cantilever alignment and relationship to the suspension, coils etc. After all, the angle of the cantilever to the body is variable, at least to some degree. It is usually hand made MC's that have cantilevers out of alignment on a more permanent basis. I agree with Wayner in so much as sending back any cartridge with a skewed cantilever. A manufacturer might tell you it makes no difference, just align the cantilever. Maybe in a practical sense it doesn't matter that much, but in an ultimate sense it does. The cartridge fixing screws should be set perpendicular to the angle of the cantilever, when centered.
I know what you're going to say about the angle of the cantilever to the groove varies, and is not a fixed relationship. Never the less, there are vibrations and forces on the cart body and arm. Geometrically it is incorrect. What if you have a linear tracking arm? At the end of your arm you have a cart that is mounted at a crazy angle? I think that illustrates what I'm talking about, and you can see how that might not be optimal? I've seen pics of carts that looked like the cantilever was off 15 degrees, and the manufacturer said it was OK, hand made blah blah blah. If the cantilever is centered, or close to centered, there will be even potential for movement in either direction, without vibrational forces being dealt with in a manner other than what was designed for with the arm.
neo
Wayner
« Reply #42 on: 1 Jul 2010, 12:10 pm »
You know, there are lots of folks out there that are getting into vinyl. IMHO, the resolution of the set-up will portray the the music. In otherwords, bad set-up will bring bad sound. Unfortunately, John takes the put your head in the sand approach, by telling folks to just stick the cartridge on the tone arm and be done with it. Well, that's one approach.
I enjoy the technical aspects of cartridge alignment, but at the same time, I have to be a realist. We are dealing with microscopic stuff here. We can't really see what's going on, so we have to use our knowledge and skills to get to these places we really can't see.
When we start getting to the point where we recommend things like aligning the cantilever, we have lost subjectivity. Why? Because for most of use, we can't see it. Even with scopes and magnifying glasses and things like that. Then you have to ask yourself, is the stylus truely in the correct mounting on the cantilever? It's too small and too impracticable to deal with.
Procedure must be followed for success, here. First, even before attempting to align a cartridge, the stylus and cantilever must be observed. I've just looked at the 15 or so cartridges I have and the cantilevers all look and measure to be in line as I can observe. Yes, we know that it is not perfect, but on the other hand, we know it's very, very close. If it's not, get a new cartridge or replacement stylus. After this, the cartridge body can be used to confidently align to who ever's null points you wish.
As mentioned, even excessive amounts of anti-skate (or lack thereof) can change the offset angle at the cantilever, that is why correct steps must be taken to get the stylus to where we want it. If we set the cartridge and then raise the VTF (as an example) we now screwed up the alignment, because distance was consumed by the hypotenuse of the triangle. If someone where not aware of this, they would be out of position, all because of procedure. I know that raising the SRA by 2 degrees will change the overhang by about .25mm. In the alignment world, that is a big distance.
Micheal Fremer is using a USB Microscope to set the damn SRA. Is that necessary? I found a way to do with my camera, using some extreme zoom settings. I think almost everyone has camera, almost no one has a microscope. He made suggestions that are not realistic for most vinylphools.
Wayner
TheChairGuy
« Reply #43 on: 1 Jul 2010, 01:16 pm »
Wayner
:peek: Call me an ostrich if you will :wink:, but the renewed momentum that vinyl enjoys again rests with both calling back the old warriors that grew up on vinyl and the kids that grew up exclusively on perfect sound forever (or it's even grosser cousin, MP3)
As the old guard are, truly in this case, dying off...that leaves younger folks left to tend to vinyl's future.
I believe vinyl quality will be affected only by a small amount of the OVERALL total with all your nuanced recommendations on cartridge alignment, et al.  We will lose participants if our focus is the exotica and not the basics.
Getting folks back in to vinyl, having them set up with a modicum of perfection the VTF, overhang, azimuth and set the table up on a non-resonant base is plenty good enough to hear the naturalness and beauty of vinyl over digital technologies.
Yes, there is certainly a place for 'exotica' vinyl discussions....but, as this topic took on a several page life, I felt the need to inject a disclaimer for newbies chiming in.
Many see a Fac's role as that of a mediator - but, I've never seen myself as that.  I see myself as one small cog in keeping the vinyl spirit alive and well...and that means attaining and retaining newbies to the fold.
So, call me ostrich as you see fit...but I see prescient, caring, devoted or even altruistic as fitting a description for me to wear; as you would think you are equally serving the vinylphool community :wink:
Carry on folks...I won't likely be injecting any further disclaimers for newbies in as one fair warning is enough :)
John
sunnydaze
« Reply #44 on: 1 Jul 2010, 01:43 pm »
Lost subjectivity?!  I have no idea what this statement means.   :scratch:
Hey Wayner, aren't you the guy who posted pics claiming he could see a one degree difference in SRA?!    :scratch:  Hard as I tried, I could see no difference in those photos, yet I have no difficulty in seeing the cantilever....any cantilever.
Here you claim difficulty in seeing the cantilever?  After those SRA photos, just a slight inconsistency, no?   I concede, some are harder than others to work with, but I have yet to encounter a cantilever I could not see well enough with this method.  Even the short and stubby Dynavector 17D2.
I still maintain:   it is easier and quicker and more precise to line up the cantilever than the cartridge body.  Have you ever tried it?  Try it both ways and see for yourself.  I have.  And then we still have the issue of the rounded cartridge body.  What method do you propose for this?
To each his own.  Whatever gets you there is fine.  I just offer another method to get you to the same place.  I have tutored several local buddies on cantilever alignment and they concur about its ease and precision, and have adopted it.
I see you discussing lots of things, but not the core of what I have outlined.  I haven't and I don't refute what you say about VTF and SRA and the overall precision required in general.  Nor do I dispute your points of how cart setup changes as other parameters are changed.  But they have nothing to do with my points.
And what does the cantilever / stylus build quality have to do with anything I have offered?   If it is off, aligning the cartridge body offers no advantage in setup vs cantilever alignment.
I have limited my discussion to setting overhang and offset angle only.  Seems to me you are intentionally obfuscating and not addressing the issue.  You have yet to give any reasons why cartridge body alignment is superior, nor have you disputed the efficacy of cantilever alignment for setup of these two parameters.  If you have, my apologies for the oversight.
sunnydaze
« Reply #45 on: 1 Jul 2010, 01:52 pm »
Sunnydaze,
Thanks for the input.   So let me ask you this.....
If the cantilever is 100% perfect and straight, why is cantilever alignment no good...or at least inferior to cartridge body alignment?  Unless I am mistaken, this is what Wayner is saying.
Wayner
« Reply #46 on: 1 Jul 2010, 05:51 pm »
Yes, I could see 1 degree on a blown-up photo of the stylus, using a really good protractor and drawing some lines on the copy I made. There is no way I could tell from just eyeballing it. I used tools to help me determine that particular SRA.
Sunnydaze, I think we agree on most issues, and I think the problem might be that I love MM cartridges and you might love MC cartridges. MC styluses are right out there in the open on many designs and for the average guy, they might be able to line up the cantilever with some grid lines.
My MMs are realy close to the record surface. You just can't see under there to look at the stylus or cantilever. Is this the case? I guess If you can do your Kuzma method, then good, I can't.
That is why I approach the problem differently. It's kind of a handi-capped way of doing it, but then, most cartridge alignment tools go about it the same way. Like I said in my earlier post, if you can visually look at your cart and tell that the cantilever looks square to the world, then I think you can use the body to help align the damn thing.
To be honest, none of this stuff is really the right way to fit a cartridge to an arm. It's kind of backwards. If I could figure out how to design it to work for any cart, this is what I would do. I'd design some kind of holder that you could set the cartridge into. That holder would be positioned so that it had the overhang, SRA and all that neet stuff built right into it. Then you would bring the arm over to it and mount the arm to the cart in that static position. Sounds good, but since the RIAA and NAB didn't come up with any standards, all of the carts are all different and I'm clueless how this could be done.
At any rate, perhaps John is right and all we are doing is scaring the newbies or confusing them. Time to take a pill.
Wayner
jazdoc
« Reply #47 on: 1 Jul 2010, 06:03 pm »
This has been a terrific discussion but I could see how it could scare off newcomers to vinyl.  I have had great success with the MintLP arc style protractor.  It comes with great instructions and the results were readily audible.  If someone like myself who is hand-eye coordination "challenged" can use this, anyone can  :thumb:  Thom Mackris of Galibier once told me that he believes most folks settle for 'good' from their vinyl rigs but never hear the full potential of their system.  Working to get alignment parameters from 90% to 98% dialed in makes a huge difference.  The last 2% is even more rewarding.  Best of all, the cost is signficantly less than any cartridge, cable or other hardware upgrade.
shep
« Reply #48 on: 1 Jul 2010, 06:20 pm »
I think it has not been yet posted, or I missed it, there's a rather lengthy article on the subject on the Stereophile web site. Front page "Listening #90".
BobRex
« Reply #49 on: 1 Jul 2010, 07:06 pm »
Hey Mark, how's that Talea working out?  I've been drooling over the pictures for a while now, but I'm still in the air over a table upgrade.  Right now a Gavia + Talea is high on the list - assuming wifey lets me open the checkbook.
BTW - how do you adjust overhang on the Talea?  Is the mounting plate slotted or is everything done back at the post?
blakep
« Reply #50 on: 1 Jul 2010, 11:46 pm »
I have added a few of my own tricks to make things even easier and more accurate:
(1)  On the protractor,  I put a pin hole at the two null point cross-hairs.  This means less eye strain and makes it real easy to get the stylus in perfect position every time. Just drop the stylus in the vicinity, and then gently move the platter / protractor to and fro till stylus drops into hole.  Bingo!  (Before starting I remove all bias and use minimal tracking force to keep cantilever from twisting and flattening)
(2)  I also lay a bright mag light on the platter shining on the work.  This, and a simple magnifying lens, makes it very easy to see relationship between cantilever and black line, and always results in very accurate and quick setup.
I'm in full agreement with aligning the cantilever. FWIW if you use an arc protractor like Conrad Hoffman's or the Mint (Providing you know P to S distance), locking in the correct overhang on the arc will give you instant perfect alignment if your cantilever is straight.
I was going to order a Mint myself, but after printing Conrad's free protractor on high quality photo paper, laminating it, taping it to a scrap record and aligning with one of these:
http://cgi.ebay.com/20-X-JEWELERS-LOUPE-EYE-ILLUMINATED-MAGNIFYING-GLASS-/230374181243?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item35a35f097b
I feel absolutely no need to order the Mint.
Just my opinion, but a pin hole in the protractor is not a good idea. Having gone that route myself in the past I feel that:
1) chances are that the cantilever will be skewed to one side or the other depending on which side of the hole you are dropping in from, resullting in less than ideal alignment and
2) one false move and you might be ripping your stylus/cantilever off.
neobop
  • BIRD LIVES
« Reply #51 on: 2 Jul 2010, 12:24 am »
I didn't say cantilever alignment is no good. I was discussing cantilevers that are off center at the stylus end, and some of the implications. As a matter of fact, another aspect is the mounting screws in relation to the cantilever where it pivots into the body. A skewered cantilever throws the geometry out of whack in relation to the arm and cart mount.
As I said previously, this is in an ultimate sense and a slightly off cantilever will sound better aligned to the cantilever, if the angle can't be corrected. Sometimes that's just the way it is, due to imperfect setting of the generator parts.
I really don't see this discussion as something that will scare off newbies. Many have heard the potential of a modest TT set-up. Even if it doesn't have the nth degree of resolution, it usually sounds more natural and enjoyable. That is, if it's set up decently. So, while they are reading something about the fine points, and a good lively discussion at that, they will probably realize that there really is something more here than putting a disc in the tray or downloading. Sure, you can have your dealer set up your TT. But all this effort and discussion is for a reason - just how damn good it can sound.
neo
TheChairGuy
« Reply #52 on: 2 Jul 2010, 12:37 am »
Neo
Newbies have indicated otherwise.
That the set-up and lingo in vinyl keeps them away...and topics like make them think that the effort to get good sound from vinyl isn't something they want to take time to do.
It's for that reason that I want to tell them that one does not have to pay attention to the exotica...that the basics of decent setup is often good enough to hear the inherent benefits of vinyl over digital technologies.
Newbies came out of the AC woodwork and asked a lot of questions they had pent up in this topic: http://www.audiocircle.com/index.php?topic=65302.0
The responses here confirmed what I suspected - if we keep at this hi-fallutin' exotica discussion among experienced vinylphools. we're gonna' lose a lot of the future generations that could sustain vinyl.
Sorry to break in again on the topic...but, I'm iconoclast even if others don't see what I see and know.
John
rcag_ils
« Reply #53 on: 2 Jul 2010, 02:13 pm »
Some of the cartridge components we can't see, but we sure can HEAR. I can hear the difference when the anti-skate is misadjusted, that's why it's so important to have a test record that will test the anti-skate adjustment. If 92 degrees (which I can't see easily) is the reference, then anything > 92 will increase the treble, < 92 will increase the bass, your VTA adjustment would just become your tone control until everything's balance. The objective here is listening to the music, not peek at them.
sunnydaze
« Reply #54 on: 2 Jul 2010, 02:32 pm »
Once stylus drops into the pin hole, I simply wobble the platter slightly to and fro to seat it and center it properly .   Then, a quick look with the magnifying glass and it is easy to see if it is centered.  If not, a gentle nudge on the arm (or headshell, or cartridge body) in the correct direction fixes things.
I find the most time consuming and onerous task of cart setup is dropping the stylus perfectly dead center on the null pt. cross-hairs.  I'm pretty careful around the table, and my hands are still surgeon steady, so I'll risk it for the greater speed, ease and accuracy that the pin hole offers.
sunnydaze
« Reply #55 on: 2 Jul 2010, 02:52 pm »
No Wayner,  I have set up both MM and MC with this method:  Dynavector,  Denon, Clearaudio, Benz,  Nagaoka, Shelter, and probably several others I can't recall.
Certainly, it is true that some are tight and harder to see than others.  And of course, if you can't get a good look at the cantilever, you can't use this method!  But I have yet to come across one.  The toughest I have personally encountered is the Dynavector 17D2......short stubby cantilever and cartridge body real tight on the record.  But I was still able to do it.  I have no idea if your cartridges are more onerous.
I can always see things plain as day by:
(1)  Removing about one gram of VTF to de-compress the suspension, raise things a hair and get a better look.  I know, I know, this will throw off the overhang a tiny lil fraction.....but I don't care as I'm not the type that can hear the effect of dust on my tonearm!   :roll:.   This is a tradeoff I am willing to make for greater ease and precision in setup.  Besides that,  my ears tell me that I always get better results this way than with my DB Systems protractor and cart body alignment.
(2) getting down real low--eyeball as close to record level as possible.
(3) and getting a good light on the work --   a small mag lite laying on the platter works best.   Before discovering this trick, I always needed natural daylight for setup.  No longer.  I can even do it in a dark room now.
BobM
« Reply #56 on: 2 Jul 2010, 04:04 pm »
This statement is mostly right, but it doesn't quite cover it all. I think people need to think of VTA/SRA in a slightly different, perhaps even a visual way.
The grooves contain wavy ridges that translate into sound. Those wavy ridges are not vertical - they are at an angle based on the cutter head. This is generally around 92 degrees. The bass ridges are longer than the treble ridges and as a result the bass ridges are less prone to VTA angle differences. The treble ridges are VERY prone to VTA angle differences since they are so short, especially the very tinkly ones like bells and cymbals.
So setting VTA/SRA is really about getting your cartridge alignment angle in synch with the treble ridges in the groove. The "perception" of more or less bass is really just one of achieving more or less alignment with the treble ridges in the groove.
What you need to listen for is a cleaner treble with a more defined transient and no smear. Once you have that set you have optomized the angle, at least for that test record.
Enjoy,
Bob
jazdoc
« Reply #57 on: 2 Jul 2010, 04:26 pm »
BobRex,
How is the Talea?  In a word...fabulous!   :thumb:  Best tonearm I've ever heard.  The cartridge is attached to a plate which is adjusted to set overhang.  I can't imagine not being thrilled with a Gavia/Talea combination.  If you have any questions please feel free to email...If you are in the Seattle area, I'd be happy to have you drop by for a look & listen.
rcag_ils
« Reply #58 on: 2 Jul 2010, 09:17 pm »
I simplified my statement. Increasing > 92 makes the treble sound splashy and unnatural, but it sounds like more treble, but actually it's mistracking. < 92 music starts to sound lumpy and muffled, but sounds like there's more bass, also mistracking. I am sure if your stylus is worn already and you try to compensate it by adjusting the VTA, it can't be good for the records. But we vinyl fans know better, and wouldn't let the stylus to wear too much before replacement.
Wayner
« Reply #59 on: 2 Jul 2010, 09:53 pm »
I've made this comment before, but if your stylus is half worn out and you change the SRA, it might not be good.
Wayner  :D
