0 Members and 1 Guest are viewing this topic. Read 21415 times.
Since most 2 point protractors are designed around either Bearwald or Lofgren's null points (where the stylus is perfectly perpendicluar to the record groove), the act of aligning to the 2 points, which usually involves using a grid pattern to match the front flat feature found on most cartridges at each point, will automatically set the overhang and the offset angle.The only physical feature that will stop any tone arm from achieving any popular null positions is just plane real estate. That means, are the slots long enough to move the cartridge where you need it. Some tables only offer 2 holes, and this is very piss poor designing, or perhaps it's a lack of understanding, regarding cartridge alignment. Wayner
Wayner,I have seen quite a few. It depends mostly on the factory alignment, how generous the headshell slots are, and the cartridge. Many mass market Japanese tables from the heyday were designed for a Stevenson-like null. With many, depending on the cart, you're lucky if you can get Baerwald. I have a Sony PS-X50, the next generation from your X7. With the stock headshell I can't use Baerwald with most carts I've tried. Since I wanted a lighter headshell anyway, I elongated the slots in one, which was longer to start out with, and now I can use Baerwald with all the carts I've tried. The TT is a semi with a height adjustable arm similar to your 1200 in adjustment. I'm not about to mess with mounting distance. Whatever works.neo
Baerwald = Lofgren A (65.998mm, 120.891mm)Lofgren B (70.285mm, 116.604)I have no clue what Stevenson's is.Wayner
So HOUSTON, WE HAVE A PROBLEM! Now another wrinkle is in the works. I also see Ortofon came out with a new series of cartridges that have a rounded front edge. Are they mad? How are you suppose to line up the cartridge with a grid without a flat edge in the front?Wayner
Good stuff, folks. Just a few points:Neo: Regarding minimum modulated groove radius, you might be interested in this: “There is a widespread misconception that the minimum allowable radius for the modulated portion of an LP groove is 60.325mm. Well, it isn’t. When I laboriously measured my LP collection 30 years ago, I found a significant proportion had minimum radii down to 58mm, which I subsequently recommended as a realistic figure to use in alignment calculations. IEC 60098 doesn’t explicitly state a minimum modulated radius…it turns out that the minimum permissible radius for the modulated portion of the groove is 56mm.” From “Arc Angles” by longtime analog maven Keith Howard in the March 2010 issue of “Stereophile,” p. 56-Bob
John,Good way to attract attention: WARNING DON'T READI see Sunnydaze has stirred up a bit of a hornets nest regarding cantilever vs cart body alignment. At the onset, I think it might be helpful to get two thing out of the way. The relationship of the stylus/cantilever to the groove, is what's being aligned. It is also the cantilever angle that defines the offset angle.
