Fuse for Cornet2
0 Members and 1 Guest are viewing this topic. Read 1492 times.
Scott B
Fuse for Cornet2
« on: 26 May 2010, 05:44 pm »
I recently purchased a hi-fi tuning fuse for my amplifier, and it wasn't until I received it in the mail that I realized that I ordered it with the wrong Amp rating (1.6A instead of 6.3A).  That was stupid!  Then I thought I'd check to see what fuse the Cornet was using and looks like it's a 1A fuse.
Is 1A close enough to 1.6A or am I out of luck?
Scott
GRD
Re: Fuse for Cornet2
« Reply #1 on: 27 May 2010, 03:56 am »
Just my opinion, but I would say close enough.  And use the 1.6.  If there was a short, it would blow.
 I tried another fuse that was a different construction 1 amp awhile back and it actually sounded better.  But it was apparently a "fast blow" variety and it blew when turning on the Cornet sometimes (probably related to the location on the AC cycle when I turned it on).  Eventually blew all of them and went back to the specified fuse.  Almost bought some 2 amp versions.
So your fuse may actually sound better than stock.
poty
« Reply #2 on: 27 May 2010, 08:53 am »
Hi-Fi Fuse???  :)
Truly inscrutable the Hi-Fi ways.
Scott B
« Reply #3 on: 27 May 2010, 02:20 pm »
Thanks for the response, I'll give it a try.
GRD
« Reply #4 on: 27 May 2010, 03:03 pm »
Poty - yes, hard to believe a fuse could make a difference in the sound.  I have no ideal why and this kind of stuff can just drive you nuts.
hagtech
« Reply #5 on: 2 Jun 2010, 07:55 am »
Should be fine.  I normally use a slo-blo type to handle the inrush current of the heater supply capacitors.
jh
Scott B
« Reply #6 on: 2 Jun 2010, 02:25 pm »
Good to know.  Thanks Jim.
