0 Members and 1 Guest are viewing this topic. Read 9028 times.
As far as setup, I honestly don't know. I put the new cart in as square to the headshell as I could by eye. Looks level front to back.
Wayne, I surely appreciate your help. I'm stuck at the hospital most of this week, but when I get some free time after the holiday, I'll try to follow up on this.I'm leaning toward getting a Rega P3-24 w/ a factory installed cart. at this point and just be done w/ it.But then again, I've read some reviews that say Clearaudio's entry level table (the Emotion?) is a killer deck, though at the high end of the entry level price range.
Ante up and spring for the P5. It's a fuss free, dependable deck with a good arm (RB700). I have a good friend who went from a Clearaudio Solution/Satisfy to the P5. P.S.I owned the Emotion and sold it. It's fussy in that you have to clean the belt rather often. If you don't there's lots of rumble. I have a P5 now. Only hassle is switching from 33 1/3 to 45 and back. Without the optional speed controller, you have to remove the platter to switch pulley positions.
