a/v1rs build
0 Members and 1 Guest are viewing this topic. Read 1511 times.
[email protected]
a/v1rs build
« on: 20 May 2010, 03:19 pm »
I think these top baffels need to be recut. The distance between the 2 speaker openings is to short. Seems I did some math wrong or I didn't allow for the pin in the circle cutter. Anyone know what the minimum distance between the speakers will work.
S Clark
Re: a/v1rs build
« Reply #1 on: 20 May 2010, 03:51 pm »
Those should work fine.  Having the woofer overlap the tweeter is something that Danny does on purpose.  I wouldn't start over just to try to get an extra 1/8" between drivers.
Danny Richie
Re: a/v1rs build
« Reply #2 on: 20 May 2010, 10:47 pm »
You are a little too close.
They need to be 4.75" apart and look like this:
