Warranty start date
0 Members and 1 Guest are viewing this topic. Read 2095 times.
onthefly
Warranty start date
« on: 18 May 2010, 09:13 pm »
Does the Bryston warranty start from the build date or the date on the purchase invoice.  I might be buying a BP26 tomorrow that is exdem and advertised with 20 year warranty.  :eyebrows:
werd
Re: Warranty start date
« Reply #1 on: 18 May 2010, 09:38 pm »
Hi
build date
Robert D
« Reply #2 on: 18 May 2010, 09:47 pm »
Werd
Off the Topic
Your 14B SST²  does it have new Capacitors  & New Type of transformer
I'm Curious
Robert
werd
« Reply #3 on: 18 May 2010, 11:50 pm »
Werd
Off the Topic
I'm Curious
Robert
Hi mr d
Yes  to both and choked too. You really don't need the torus with the 14B  imo. Anyone with a 4B thinking of buying  an rm20 would be better off just getting right into the 14Bor 7Bmodels and plugging right into the wall.
drummermitchell
« Reply #4 on: 19 May 2010, 12:15 am »
Keeping my Torus(s)in front of my amps,lets me sleep easy at night,especially with the added protection,it's not all about the new tranformer or caps.There's a little bit more in them there Torus(s)
                                            Mine will stay,even when I upgrade :thumb:.
Robert D
« Reply #5 on: 19 May 2010, 12:58 am »
Werd thanks for your feedback
I can understand your thoughts that more power is always better.
My 4b’s since the upgrade have opened up.
I can hear my speaker’s take a breath of fresh air.
1)Mids and lows very happy seems like the new capacitors have or need less volume.
2)Bass is smooth with more detail.
3)Highs are clean rich with more detail.
4)Separation of the instruments is more profound much more detail.
Regards Robert
werd
« Reply #6 on: 19 May 2010, 02:38 am »
Regards Robert
Hi Robert
Hi
There is actually an upgrade conundrum in the path between the 4B and 14/7B. The 4B undoubtedly needs the Torus, You can hear
the compression if its plugged into the wall. The 4B and torus are excellent together and its a clear upgrade strategy. But the new 14Bs have the same transformer
that the Torus use. That transformer allows the amp to breath effortlessly (clearly audible). Any body with a 4B and a Torus
knows what i am talking about.
The conundrum is that the 14B/7B doesnt need the torus for that reason anymore. And the price for the rm20 and the 4B are what
you would pay for a 14B approx. Having owned both the 14B and the 4B/torus, the 14B really is an different league than the 4B/Torus combo. And the 4B is phenomenal, you wander
how it can get any better, until you go higher up the Bryston line.
So its kinda screwy right now with these transformer upgrades 14B and up. I personally don't like the 14B plugged into the Torus anymore. Its Brings the
soundstage to far up and you kinda loose depth.
Robert D
« Reply #7 on: 19 May 2010, 12:35 pm »
Werd thanks for those comments.
I guess you hit the Nail on the Head concerning the Torus units. And the larger Bryston Amps.
As far as power goes my 2 4Bs’ are sufficient for now. I had a thought to up grade them to 2 7B’s but I’ll keep my 4b’s and eventually up grade to 2 x 28B’s
For now I’ll stick with my set up.
Business has been tuff over the last few months.
The wife is still on the renovation trend.
Regards Robert
alexone
« Reply #8 on: 19 May 2010, 05:31 pm »
Regards Robert
...the wives are ALWAYS doing something... :lol:
al.
