USB Type A Connectors
0 Members and 1 Guest are viewing this topic. Read 1913 times.
NagysAudio
    • http://www.nagysaudio.com
« on: 6 May 2010, 07:27 pm »
Anyone know of a good source(s) for USB Type A male connectors? Ideally I would want the following specs, but I will take all suggestions:
- Copper pins, silver plated.
- Solder type pins.
- Teflon dielectric.
- Black hood cover.
sts9fan
Re: USB Type A Connectors
« Reply #1 on: 6 May 2010, 07:57 pm »
spaceship factory.  Google is your friend  :duh:
NagysAudio
« Reply #2 on: 6 May 2010, 08:00 pm »
Oh yeah? Why don't you google it and see what you come up with.
jtwrace
    • TIPP YouTube Channel
« Reply #3 on: 6 May 2010, 08:02 pm »
He probably meant http://www.spacecraft.com/index.html
I don't think they have USB though.
sts9fan
« Reply #4 on: 6 May 2010, 08:03 pm »
oh your internet must not be as good as mine.  Time to upgrade.
NagysAudio
« Reply #5 on: 6 May 2010, 08:04 pm »
Ok, can you send me a link of a connector that meets even 1 of my 4 criteria?
ebag4
« Reply #6 on: 6 May 2010, 08:08 pm »
Or this: Space Shuttle Hi-Tech Co., Ltd, http://www.spaces.com.tw/
But they appear to have complete cables, not components.
Best,
Ed
*Scotty*
« Reply #7 on: 7 May 2010, 12:33 am »
Norbert, to my knowledge there are no USB type A or B connectors that meet your criteria available as an off the shelf component.
Here is what I found for connectors that have solder-able pins.
http://www.l-com.com/item.aspx?id=7236
Scotty
Scott F.
« Reply #8 on: 7 May 2010, 12:52 am »
I agree. You will be limited to just gold plated contacts and solder pins.
I bought mine from Mouser;
USB offerings
I ended up using several layers of heat shrink to shroud the raw USB connectors when I built my 5 meter silver plated copper/teflon USB interconnect for my DAC. The Mouser offerings work great.
NagysAudio
« Reply #9 on: 7 May 2010, 07:27 pm »
Yup, that's what I thought unfortunately. What about a black cover hood? Any sources for those? I see plenty of off white hoods available...
sts9fan
« Reply #10 on: 7 May 2010, 08:12 pm »
All about the sound. Black sounds best?
Bob in St. Louis
« Reply #11 on: 7 May 2010, 09:20 pm »
Cryo'd sound best.  :icon_twisted:
jrebman
« Reply #12 on: 14 May 2010, 03:16 pm »
I'd suggest calling a furutek dealer or distributor and asking whether their USB connectors will be available for individual purchase.
  I believe the shells are metal and nickel or chrome plated.
-- Jim
