0 Members and 1 Guest are viewing this topic. Read 14582 times.
Thanks boys for your input. Another one: 220Volts mains line/gear is always better than 110/120V(this is not a secret, everybody knows it).
For amplifiers or all components? I ask because 120 vac is easily just as good for preamplifiers and smaller energy devices. Cheers.
In my personal experience as audio custumer since 1974, 220/230/240Volts is better sound for all gear, inclusive video equipment.Regards, Gustavo
Thanks Steve.
Thinking about it further, some preamplifiers do have lots of tubes or SS and could draw several amps, which could change sound with 220 operation. Maybe not all but at least a few. My apologies Gustavo.Cheers.
Hi Gustavo, Wire and their metal properties and guage is a topic that has weighed heavily in my mind of late.
Hi Gustavo,No, the liquid conductor itself does not suffer from oxidation but there is, of course, metal connectors on each end so they will suffer this problem with certain metals. That's why rhodium has been so popular for many years and in so many applications.Best,Jake
Hello Steve,Maybe it is my fault, my english may had fail here. I mean said I prefer 220Volts equip in relation to the same 110/120Volts gear. Regards, Gustavo
My old Sony SCD-1 is USA model 120Volts, but I prefer the Euro 230Volts version,.....
I find it hard to believe interconnects carrying signal voltages under 10 volts and in the milliamps level to be oxidizing in two years. Jake
Another tip for good tube heat dissipation, a brazilian tube hobbyist inform me this one: >> Black anodized aluminium is the best material for heat dissipation in a tube amp chassis or tube table(magnesium is ever better), the second best is black painted aluminium.
>> For good sound quality the best chassis is solid real wood.
>> Painted steel chassis has low heat irradiation/dissipation, same for Inox steel, but are good for RFI shielding.
>> Some tube amps builders use brass for tube table or chassis for good sound quality(I can not say it have great sound, as I never listen a such amp yet, but the heat dissipation is no fast as anodized aluminium).
