New capacitors that Bryston is installing in their Amps
0 Members and 1 Guest are viewing this topic. Read 15630 times.
Robert D
Looking for feedback on The New capacitors that Bryston is installing in their Amps. :drool:
Regards Robert
Robert D
Re: New capacitors that Bryston is installing in their Amps
« Reply #1 on: 2 May 2010, 12:43 pm »
I have 2 X 4BSST² to send in for Up Grade
Robert
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 2 May 2010, 12:49 pm »
Hi Robert,
INPUT CAPACITOR CHANGE and FEEDBACK CAPACITOR CHANGE:
We have implemented the use of some very specialized capacitors in a number of key areas in the circuitry.  There is a consistent improvement at high frequencies near and  above 20K, and up to over 60KHz. These specialized capacitors are installed at both the input stage and the feedback loop of the amplifier circuitry.  These capacitor changes affect all new SST² amplifiers.
The upgrade is only available for ‘SST²’ amplifiers ‘NOT SST’ or previous models.
At Bryston we are continually trying to improve the performance of our products. Please be aware that these changes are 'evolutionary' not 'revolutionary' in nature. They will provide subtle to noticeable improvements depending on your specific system and setup.
james
Robert D
« Reply #3 on: 2 May 2010, 01:03 pm »
Thanks for the feed back James
Robert
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #4 on: 2 May 2010, 01:13 pm »
If you can spare the money for it: do it. It is worth it.
I went for the slightly more radical road and just bought a whole new amp (also because my old 4B SST2 was silver, the new one is black).
In my opinion James is rather modest here, with the 4B SST2 model at least the change is quite significant.
Robert D
« Reply #5 on: 2 May 2010, 01:38 pm »
Here are my 2 Babies
Looking forward to them coming back...
They have not been sent in yet
Robert
Laundrew
« Reply #6 on: 2 May 2010, 01:46 pm »
I did notice a difference in the audio between the amplifier I auditioned in the showroom compared to my “post” modified amplifier that I purchased. At the time, I thought that it was all about the difference in room acoustics - I see that there was much more to this.
Be well...
Robert D
« Reply #7 on: 2 May 2010, 01:49 pm »
James what is the turn around time to have the New capacitors installed?
Thanks Robert
« Reply #8 on: 2 May 2010, 02:38 pm »
About a week from when we receive it.
james
redbook
  • the music is the blood...........
« Reply #9 on: 2 May 2010, 03:24 pm »
Hello James and all the gang. Are all sst2 amps manufactured from this date onwards will have these improve caps? What serial number on a 4b sst2 should I make sure I get from my local dealer ( don't want the old stock by mistake) Tnaks again.......... :violin:
« Reply #10 on: 2 May 2010, 03:47 pm »
Bryston Serial Numbers for Capacitor Changes:
3B - SST² - 001642
4B - SST² - 004719
7B SST² – 001808
14B SST² – 000677
28B - SST² - 000180
mr_bill
« Reply #11 on: 2 May 2010, 04:53 pm »
James,
This post would be good to make a 'sticky' in your forum, for future reference
3B - SST² - 001642
4B - SST² - 004719
7B SST² – 001808
14B SST² – 000677
28B - SST² - 000180
« Reply #12 on: 2 May 2010, 05:09 pm »
James,
Hi Bill,
Yes it is there already. I was just being redundant - redundant: :D
james
mr_bill
« Reply #13 on: 2 May 2010, 05:23 pm »
Way ahead of me!!
Alpha10
« Reply #14 on: 12 May 2010, 09:02 am »
Hi James
First post so please be gentle  :oops:
Is the 9BSST not being updated in the same way, I notice it is not on your list?
Cheers
3B - SST² - 001642
4B - SST² - 004719
7B SST² – 001808
14B SST² – 000677
28B - SST² - 000180
« Reply #15 on: 12 May 2010, 10:54 am »
Hi Alpha,
Gentle it is sir!  Yes it is in the works. The problem is the size of the new capacitors are larger than the previous version so we have to do some modifications on the circuit boards to allow for the new caps.
james
Alpha10
« Reply #16 on: 12 May 2010, 11:30 am »
Excellent news, do you have a timescale for the works?
Hi Alpha,
james
« Reply #17 on: 12 May 2010, 12:41 pm »
I will check.
james
As of last week the 9B and 6B have the new input capacitors.
james
« Last Edit: 12 May 2010, 02:25 pm by James Tanner »
Alpha10
« Reply #18 on: 13 May 2010, 12:50 pm »
Thank you very much.
redbook
« Reply #19 on: 13 May 2010, 02:18 pm »
Any price increases on a 4b sst2 amp? Thanks. :weights:
