New capacitors that Bryston is installing in their Amps
0 Members and 1 Guest are viewing this topic. Read 15631 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: New capacitors that Bryston is installing in their Amps
« Reply #20 on: 13 May 2010, 04:36 pm »
Any price increases on a 4b sst2 amp? Thanks. :weights:
HI,
There was a price increase on April 1st - nothing in the near future I am aware of assuming currency exchanges stay relatively neutral.
james
vertigo_vh72
« Reply #21 on: 14 May 2010, 01:49 pm »
Hi James,
Is there a modification for the 2BSST2 on the way?
« Reply #22 on: 14 May 2010, 01:59 pm »
Hi James,
Hi,
No further changes on the 2B SST planned.
james
Robert D
« Reply #23 on: 18 May 2010, 12:26 am »
Hi Robert,
INPUT CAPACITOR CHANGE and FEEDBACK CAPACITOR CHANGE:
We have implemented the use of some very specialized capacitors in a number of key areas in the circuitry.  There is a consistent improvement at high frequencies near and  above 20K, and up to over 60KHz. These specialized capacitors are installed at both the input stage and the feedback loop of the amplifier circuitry.  These capacitor changes affect all new SST² amplifiers.
The upgrade is only available for ‘SST²’ amplifiers ‘NOT SST’ or previous models.
At Bryston we are continually trying to improve the performance of our products. Please be aware that these changes are 'evolutionary' not 'revolutionary' in nature. They will provide subtle to noticeable improvements depending on your specific system and setup.
james
Feed back on capacitor up grade.
1)Mids and lows very happy seems like the new capacitors have or need less volume.
2)Bass is smooth with more detail.
3)Highs are clean rich with more detail.
4)Separation of the instruments is more profound much more detail.
5) Yes James I hear a Difference Thank you
Robert
drummermitchell
« Reply #24 on: 18 May 2010, 12:46 am »
Robert,I didn't need to read that,yes I did.I take it you some happy 8).
Robert D
« Reply #25 on: 18 May 2010, 12:56 am »
Very Happy
Robert
Robert D
« Reply #26 on: 1 Jul 2010, 04:07 pm »
Looking for feedback on The New capacitors that Bryston is installing in their Amps. :drool:
Regards Robert
Take a look Here
jhm731
« Reply #27 on: 1 Jul 2010, 09:24 pm »
Can these new capacitors be installed in the PMC AML 1 amp modules?
vegasdave
« Reply #28 on: 2 Jul 2010, 02:02 pm »
Sounds good, guys. I just wish I could upgrade from SST to SST2.
servingko
« Reply #29 on: 2 Jul 2010, 02:13 pm »
What's the price for the upgrade on the 4B?  I have been needing to send mine in for some DC on power down (snapping in speakers) and should take care of this at the same time.
Deftone
« Reply #30 on: 2 Jul 2010, 09:39 pm »
Good to hear that the 4bsst2 will have the new caps.What about the 6bsst2?Will it comes with the new upgraded caps too?
« Reply #31 on: 2 Jul 2010, 10:18 pm »
Yes the 6B has the new caps.
james
Elizabeth
« Reply #32 on: 3 Jul 2010, 12:20 am »
I just HAD to go look at my 4B-SST2 serial #... Ok I got the caps built in.
alexone
« Reply #33 on: 3 Jul 2010, 03:34 am »
Dave,
the used market (for example Audiogon) offers a lot of good Bryston stuff. talking about Bryston then you guys are much luckier with "2nd hand" equipment than we are here overseas...
al.
vegasdave
« Reply #34 on: 3 Jul 2010, 06:17 am »
I see. Thanks for the info. Not too crazy about buying used, though.
Jimmy71
« Reply #35 on: 22 Oct 2014, 07:59 pm »
Here are my 2 Babies
Looking forward to them coming back...
They have not been sent in yet
Robert
Hi mr Robert do you use the 4bs as mono and how do they sound? Thank you
