0 Members and 1 Guest are viewing this topic. Read 161058 times.
I'm thinking about giving this a try. I'm using a BNC cable from my Touch and I'm not sure which adapter (cheater plug) I need to get(wired or unwired?). http://www.fullcompass.com/product/302172.htmlhttp://www.fullcompass.com/product/340728.html Also - does anyone have a link for the Acme Audio fuse?
Acme Audio productsThe EE DAC calls for a 5 x 20mm 800ma quick blow fuse. Acme Audio does not sell fuses in this value. For the modded DAC, I used a 1 amp fuse. I feel this is a safe change. If you do not want to risk the extra 0.2amps, I believe HiFiTuning offers quick blow 800ma. Furutech does not.I have not tried any other fuses in the EE DAC. I have tried Furutech and HiFiTuning in other products. Furutech does not seem to offer quick blow fuses. I would be very careful about using slo-blow in place of quick blow.In the power supplies I build for the SqueezeBox, I used a HiFiTuning. I did not feel any sound changes were worth the price difference. For a power supply I built for a Mac Mini, Silverlight felt the Furutech was an improvement in his system. Pez tried Acme and Furutech in his DIY SE amp and preferred the Furutech, slightly, but perhaps had too low a value as he blew up a few of them. At $50.00 each he decided to go back to more conventional fuses.Again, this is an area where you will have to experiment. There appears to be a different synergy with each system. I will be getting 1 amp 5 x 20mm fuses in stock within a week or so. I will note on here and on my website when they have arrived.The AES input does have transformer in the circuit to convert balanced 110 ohm to single ended 75 ohm. I would not use an adapter that wires pin 1 and pin 3 together. Pin 3 should be left unconnected. Pin 2 should be for signal and pin 1 for ground.The AES input circuit also has attenuation built into it to lower the "hotter" pro audio RF levels down to consumer levels. Perhaps the same purpose could be achieved by using the inline attenuators that John Kenny suggested from Minicurcuits. This might be a preferred option rather than deliberately mismatching impedances.
Wayne,I think he's also referencing the reviews. Stereomojo, for example, also states that the AES/EBU input is his/their favorite on the EE.
There are cables that go from the circuit board to the volume control and then back to the output connectors. I remove the cables and run leads from the circuit board direct to the jacks.An "L-Pad" resistor network could be installed at the output jacks.
An L-pad is a resistor across the + and - and one in series with the signal + lead.The values would be determined by the impedance of what you are sending the signal into and how much attenuation you would need.There are various calculators to figure this out on the web. Tube rolling and changing the fuse will have a large effect on the sound of the DAC and won't void the warranty.
Here is a simple calculatorhttp://www.troester.org/ls/lpad.htmlHere is a good explanation of how to design an attenuation network.http://www.uneeda-audio.com/pads/I would suggest building the network into a cable, first, to fine tune the values. This would also give you a chance to listen to see if there are any downsides to using the resistor network. You can try different brands of resistors to see if there is any audible difference. After all the evaluations, then you can start ripping apart your DAC.Another option would be to lower the gain of the output tube. That gets a bit more involved.
