0 Members and 1 Guest are viewing this topic. Read 163394 times.
Thanks for the comments guys. Can anyone provide me with a link to one of these coax to a 3 pin XLR cable connections?
It is readily apparent the DAC does not really sound it's best when used with just a USB cable, and that adding a quality digital cable makes a pretty big difference.
As I commented earlier, I did not find the AES/EBU to be so much superior to coax/bnc that it would be worth soldering/adapting, etc. I happen to have a good AES/EBU cable, and an AES/EBU source...and like the solid interface.....but if you have a good 75ohm digital coax cable I'd recommend simplifying your life and just going that direction. Especially given all the impedance changes that would occur.Downsize, you made the statementI'm not following. If you are using the USB input it is an entirely different input (and sample rate limited) not just the fact that you are using a USB cable only. If you are "adding a quality digital cable" then you are also needing to add a quality (read additional cost of $400+) USB-to-digital converter box too.
Fred,I can't really say how long a tube will last. It isn't being run all THAT hard. The stock circuit runs the plate current at about 4-5 mA. I'm running it at 9.5 mA. A 12AU7 is rated to 25 mA. So in non tech talk, in stock form the tube is kinda loafing around. I'm making it work a bit harder, but less than half of what it's max effort could be. The switch on the front is just for a relay to change between the op-amp outputs and the tube output. The power is on to all the sections at all times the power button is on..You description of liquid, bold and beautiful is just what I heard on my system. Great stage depth and width with a very quiet background. Running the Paul Hynes regulators on top of what has been done to the touring DAC just turns all that up, for a very high price.
Downsize: Isn't the OffRamp a USB to SPDIF converter? Does it sound good or crappy?
The Off Ramp is indeed a converter, but it has an AES/EBU output, a 12S output, and either an SPDIF output, or optional BNC output.
Downsize, you state that the OffRamp 4 is terrific, but USB cables are awful and inappropriate for carrying signal. What are you using between the OffRamp and your computer? I'd assume a USB cable.
I specifically provided Steve Nugent a silver NexGen RCA terminal to install on my Off-Ramp 3 so it would match my Crystal Cable terminations. As far as USB cables go, both my Locus Design Nucleus USB cable and my old Axis USB cable neither washed out or lost anything in the quality of the sound. Quite the opposite, in my system it was just the other way around IMHO. I used the Nucleus when I was doing my comparisons between using the Off-Ramp 3 and the EE DAC USB and while the Off-Ramp 3 in front of the EE Dac was better in my system, I was quite surprised on how close they actually were. Using my Nucleus USB cable, the EE DAC USB sounded pretty damn good. High quality USB cables makes all the difference with the EE DAC IMHO. Cheers,Robin
That sounds like a personal problem on your part that has no bearing on my countering of your blanket statement on USB cables. Cheers,Robin
