BDA-1 does not power on
0 Members and 1 Guest are viewing this topic. Read 4577 times.
satbox
« on: 25 Apr 2010, 02:55 pm »
Hello,
Since this morning, my BDA-1 seems to be dead  :(   No led is illuminated. What I have to do? Change the internal fuse?
Thank you!
Didier
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-1 does not power on
« Reply #1 on: 25 Apr 2010, 02:57 pm »
Hi Dider -
please email Mike Pickett at Bryston - [email protected]
Where did you purchase it and what is the serial number?
james
satbox
« Reply #2 on: 25 Apr 2010, 03:09 pm »
Hi James,
The serial number is BDA1-000451. I bought it in Belgium (dealer: New Music).
Didier
« Reply #3 on: 25 Apr 2010, 05:01 pm »
Hi James,
Didier
Ok we will try to find out whats going on for you Monday.
james
satbox
« Reply #4 on: 25 Apr 2010, 05:52 pm »
OK, thank you James.
b5pt9
« Reply #5 on: 25 Apr 2010, 05:58 pm »
Mine freezes sometimes and I have to cycle the 120v input power off and on, then it's fine again for another few weeks or months.  Requires a s/w update apparently but I haven't got around to it yet.
ian.ameline
« Reply #6 on: 26 Apr 2010, 02:01 am »
Mine did too until I got a software update.
If it is not responding at all, it may need to go back to bryston for the firmware update.
I haven't had any problems at all with mine since the update.
satbox
« Reply #7 on: 26 Apr 2010, 04:57 pm »
Hi James,
Any news concerning the problem I have with my BDA-1? Can I check by myself if the fuse is blown and replace it without losing the guarantee? (I have Torx drivers and it's quite easy...) Is it a standard FAST 125ma fuse (my BDA-1 is a 240v) 5X20MM?
Thank you!
Didier
« Reply #8 on: 26 Apr 2010, 05:41 pm »
Hi James,
Thank you!
Didier
Hi Didier - please give Mike a call at Bryston - 1-800-632-8217
james
satbox
« Reply #9 on: 26 Apr 2010, 06:00 pm »
OK, I'll send an email to Mike (my english is too bad to phone him :oops:)
« Reply #10 on: 26 Apr 2010, 06:33 pm »
Hi satbox,
Talked to engineering and try this -
We've had some 240V units blowing fuses when plugging in to AC.
We have increased the fuse to T160mA and no problems since.
Dan
satbox
« Reply #11 on: 26 Apr 2010, 06:52 pm »
Thank you.
- Can you confirm that I can change the fuse without losing the guarantee?
- Is it a 5X20MM T160mA fuse?
Didier
95Dyna
« Reply #12 on: 26 Apr 2010, 07:06 pm »
Hallo en feestelijk inhalen, Didier.  Not to worry, your English is much better than my Dutch. :thumb:
Bill
« Reply #13 on: 26 Apr 2010, 09:09 pm »
Thank you.
Didier
I will check on the fuse size for you - no problem with the warranty.
james
« Reply #14 on: 27 Apr 2010, 03:11 pm »
james
Hi,
Yes, 5x20 is correct.
james
satbox
« Reply #15 on: 27 Apr 2010, 03:44 pm »
Thank you James.
I'll keep you informed!
satbox
« Reply #16 on: 1 May 2010, 02:41 pm »
Hi,
I have changed the fuse with a T160mA and now all is OK :P
Thank you!
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #17 on: 2 May 2010, 12:54 pm »
Hello Satbox!
Just because I am curious, did you use a "standard" fuse? I would really like to know whether the use of so called high-end fuses makes any difference in Bryston equipment. Could you try and find a "Furutech" fuse like this in Belgium? They are not cheap, but might well be worth the investment.
De dealers in belgie: http://distribution.audio-life.nl/furutech_dealers
Meer informatie: http://distribution.audio-life.nl/index.php?pid=236
satbox
« Reply #18 on: 2 May 2010, 01:00 pm »
Hello Satbox!
Hi,
I used a standard fuse. I know these "high-end" fuses but not really convinced... :wink:
Anonamemouse
« Reply #19 on: 2 May 2010, 01:18 pm »
If I owned a BDA (which, incidentally, is on the wishlist) I'd open my wallet to see if a 2000 + euro device runs better on a 38 euro fuse instead of a 0.05 euro one... An experiment worth the money.
Hier is wat leesmateriaal (in dutch, not worth the click if you don't speak/read Dutch)
