0 Members and 1 Guest are viewing this topic. Read 24971 times.
Blairare you saying that there is no difference between SS and tube ractification?I have read somewhere :"Tube rectifiers provide a slowly increasing DC voltage to the output tube plates as the rectifier warms up. This has an amazing beneficial effect on the output tubes - it minimizes a phenomenon called cathode stripping. This phenomenon occurs with solid state rectification."and"In listening tests, I have found that solid state rectified tube amplifiers have certain characteristics of solid state amps - quick response time and more edge. In contrast, tube rectified amps are slower in nature and less sharp in sound. The music from these amps is more round and mellow. Solid state rectified tube amps are agressive in nature whereas tube rectified amplifiers are laid back. In general, I find solid state rectified tube amps to be excellent for rock 'n roll. Tube rectified amps are really good for classical music."what is your take on that?Mariusz
Blair - Got the pm.What type of power cord will be on the demo unit?Two tubes, or 3 like the unit you built for another user?
OK Blair but why offer an option of tube ractification then?Mariusz
hmmm,, just read the posts above,, OK,, that makes sense about loading a power supply. With this particular pre,would there be any audible difference with tube rectification? LOL maybe we are getting too hung up on rectifiers. I cannot wait to get this pre in my rig,,seperate power supply for the tubes eh? Pretty cool.So if I undersrand you correctly,, a pair of tubes in this baby should last a looooong time. Pretty smart build there sir.
Mr.Blair,, I've been following your posts and gear for sometime,,I really like your approach,now,, never having met you,may I ask,,How long have you being doing this? Reason is,, you appear to have the same philosphy about tubes and their longevity (thats a good thing) as Bob Carver does. When asked about his newest tube amps his reply to the tube compliment,, "they should last 18-20 years".Anyway,,you certainly appear to know your craft,,thank you for allowing me the opportunity to audition this pre-amp.The anticipation is building.
