0 Members and 1 Guest are viewing this topic. Read 4447 times.
Hi folks I want to move to a computer based music server setup but have never owned a laptop or a mac. I have always used desktop PC's at work and home and a CD player for a source. This is for an audio only stereo setup. I have a very quiet listening room and this may sound like a silly question but do laptops have fans? Whenever I have been shopping for a laptop there is always a lot of ambient noise so I can't tell. Some claim that the Mac mini is a great setup for a music server. Does it have a fan? Also the latest mini has been upgraded and comes standard with like a 2.2ghz processor and 2 gig ram. I assume this would be fine for music serving and that I would only need the extra ram if I was running windows on it? Also, will a MAC output high res audio from the USB or it's optical SPDIF, or is it limited to 16/48k like a pc laptop. This is all new to me but I do have friends and relatives who have experience with laptops for audio and also with unix and mac knowledge so once I decide on mini or laptop then I should be able to get any help I need. One last question. Are the music files interchangeable between mac and pc's. I would be using lossless encoding or wave files or maybe high res files.ThanksBrian
The fan and the hard drive both are sources of noise. I've been told on this site that netbooks equipped with SSD are silent but I was also told they only cost $300 and since I can't find such an animal, the no noise claims are also in doubt.
I prefer a Mac Mini + external hard drive. Yes, Mini's have a fan, a very quiet fan. I have never heard the fan in my computer...however the external hard drive's fan is audible. I play AIFF (files) in iTunes through a USB cable to an Ayre USB DAC. I'm quite happy with the result.
I stopped using my mac mini Lacie look-a-like HDD within a week after i bought it as the noise was just too much for me to bare. It does make a nice stand though... To avoid the external drive fan noise, go after the portable versions as they will run off of the bus powered USB port like a Western Digital or Seagate. If you have to have FW800 you can use G-Tech(now hitachi) HDDs but are costly for a slight speed increase. Even some of the WD and Seagate desktop external drives are also fanless but you will have a power wart..
The fan and the hard drive both are sources of noise. I've been told on this site that netbooks equipped with SSD are silent but I was also told they only cost $300 and since I can't find such an animal, the no noise claims are also in doubt.I would think that flac is the most widely used lossless format as it allows meta data tagging, an essential if you move stored music around.
Chad:May I ask where or how you found these bargains? Steve/SRB places the cost of a 128Mb SSD @ $225 to $400 and yet you have a Asus netbook that only cost $279 including 2 SSD. Even allowing for needing a remote storage drive, these prices just don't seem realistic to me. USB cables that cost more than $1000 are also unrealistic in the other direction, of course.
Hi everyone Thanks a lot for all the input. I am new to this so this discussion is very useful to me. I have never been a Mac guy but lately I am getting pretty fed up with all the overhead that goes with using a PC based computer. The MAC just seems like an easier road but I would like to have file compatibility with friends who are using PC's. Because of all the PC history at work and at home I imagine there would be times that I would want to run windows on a mac mini. When running windows on a mini do I need 4gb ram? I am thinking of the base mini with 4gb ram. I would be using an external HD for music storage. Would I need a larger internal drive on the mini to run windows?Thanks again fort he input.Brian
BTW, as far as I know Apple Lossless can't encode to 24/96. Someone correct me if I'm wrong. Another consideration when deciding what format to use.
