0 Members and 1 Guest are viewing this topic. Read 15939 times.
Haven't you answered your own question by using the Havana DAC?Tubes rule. Matched carefully, an all tube system is not too much of a good thing at all. I have one, including an Havana with upgraded caps which rivals or beats much more expensive tube and SS CDPs I've had here.
Actually the Havana (which like you also has upgraded caps) is for my already ripped files stored on an external HDD via the netbook and Foobar. My interest in another CD player is because I'm not really inclined to rip the other 200+ CD's that I have thus the question about the merits of a tubed vs. non-tubed cdp into my system......
So why not just connect the Havana with a digital IC to your existing CDP or to a "new" transport? I can't imagine any inexpensive CDP, tube or SS, is going to sound near as good.
Ummm.. because the Sony PS-1 has no digital input.
Hi Rob,Having never owned the Havana, I can't comment on it directly. However, I did own it's brother -- the Paradisea. I enjoyed that DAC very much, but to my ears it was not any "better" than any of the one box players I have mentioned here. (I connected it via digital output of all my cd players). Matter of fact, I sold the Paradisea before I sold any of the other players, and I still have the Metronome in my main system! So take from that what you will.I have no idea how the Havana compares to the Paradisea. If it is significantly better, then you may very well be correct. Then again, it is quite possible that I have a tin ear!
However, I found the Cary 308T (and the 303-300) to sound slow and sludgy in the systems I heard them in....
Hi Rob,Maybe I'm confusing the issue here. I was actually asking how I would be able to hook up 2 sources simultaneously to the Havana if they are both using spdif outputs, i.e. the CDP and the netbook (I have an M2Tech HiFace USB to SPDIF converter on the netbook). The Grover cables are very tight and if I wanted to swap between the sources often I would have to swap the cable as well, no? I suppose I could use some sort of switch but that's not really ideal either....
I need the sludge....to mask the digital nasties!
Oh! You're right, you can't without switching cables. I assumed you were going straight USB into the Havana.
