0 Members and 1 Guest are viewing this topic. Read 4249 times.
The last time the amp was rebiased was when I bought it, which was...wow...almost two years ago.I actually just swapped the old DAC back in, and didn't notice the same problem. Maybe it's the new DAC afterall. Break-in issues?Anyway, I probably should do the rebiasing thing.Thanks.Chad
I can't answer that one but I think that you'll find that it's more of a bias check than an adjustment most of the time and that adjustments will be due to the voltage coming out of the wall/power conditioner at the time you're doing the checking.
Biasing tubes in an amp is usually a breeze. Just follow the instructions from the mfr and set up your DMM accordingly. I keep my DMM permanently plugged into my McAlister PP amp and check the bias at least once a week. It takes 2 minutes.
Well, ChadH, did adjusting the bias alleviate your problems?
Where is your volume control? On DAC? On Preamp? On amp? Does it seem to produce the same volume in the same position for both DACs? The output level in volts from one DAC to another can vary. The suggestion above that the second DAC might be overdriving your amp was my first thought as well. You can determine this comparing output voltage spec for both DACs and by noticing how high you need to turn up the volume control with each unit.Maybe your new acquisition is faulty. Maybe you have discovered the opposite of system synergy. Have you done a double blind test? I've read that those are very reliable and can solve any problem.
