When do you start to think it's time to adjust bias?
0 Members and 1 Guest are viewing this topic. Read 4246 times.
rockadanny
Re: When do you start to think it's time to adjust bias?
« Reply #20 on: 8 Jun 2010, 10:13 pm »
Fullrangeman - Joule requires much more often is likely due to your output tubes - 6C33 Russian triodes. From what I've read they are not as stable as most other tubes. Not a knock, as they sound glorious and seem to last long (to/for me). I check mine about every 20 hrs of use, and always seem to require some tweaking. But easy to do and sound is wonderful.
« Reply #21 on: 8 Jun 2010, 11:07 pm »
OK, many thanks for inform me about your amp.
Regards,  Gustavo
