WTB or will pay to have someone make me a Headphone Stand
0 Members and 1 Guest are viewing this topic. Read 4557 times.
R_burke
For use with my Sony MDR SA5000s - it can't be something that utilizes a "hook" the Sonys have a wide mesh band and a hook would pierce or at least deform the band.
I love wood, but the standard Sony stand is OK too
BTW I'm cheap  :oops: so don't wan't to pay much more than $50 for one
S Clark
Re: WTB or will pay to have someone make me a Headphone Stand
« Reply #1 on: 24 Mar 2010, 03:50 pm »
Just for grins, I might put one together for you out of Juniper.  Send me a PM.
Scott
Scottdazzle
« Reply #2 on: 24 Mar 2010, 07:20 pm »
In case you or someone else decides to go "not cheap" look at these.  They're available at elusive disc.  No, I'm not affiliated in any way, I just think they look cool.
R_burke
« Reply #3 on: 24 Mar 2010, 09:57 pm »
I did see these, in fact someone brought one to a head-fi GTG I attended a while back and they are nice, but way too damn expensive @ $176 + shipping
srb
« Reply #4 on: 24 Mar 2010, 10:06 pm »
Those are nice, and minimalist simple.  I was originally pondering how I might build a rack, and thinking about something adjustable, came up with a design requiring 6 pieces - a base, a column, a cross piece and 3 horizontal supports (2 adjustable).
Now after seeing this, I'm wondering what I would have to charge to render this design in one solid piece of wood.  With it's inherent weight and some non-slip feet, it would be resistant to moving.
baldux
« Reply #5 on: 24 Mar 2010, 10:08 pm »
If you're looking for a real wood headphone stand I can highly recommend you following source here:
http://home.comcast.net/~powert7/
I'm also not affiliated in any way with the builder but what can I say I'm owning one of these.
They are even more beautiful looking in real.
gerald porzio
« Reply #6 on: 24 Mar 2010, 10:10 pm »
Use a manequin head. They're available. Google is your friend.
ted_b
« Reply #7 on: 24 Mar 2010, 11:52 pm »
I use the inexpensive but padded Sennheiser stand.  It is a small vise grip-like holder that attaches to a bookshelf or any flat surface edge.  $17
http://www.sennheiserusa.com/serviceandsupport_part-finder_accessories_510615
R_burke
« Reply #8 on: 25 Mar 2010, 01:18 am »
would you measure the holder portion for me, how wide is it, and is there any space between it and the "L" portion of the bracket
Appreciate it
Richard
ted_b
« Reply #9 on: 25 Mar 2010, 01:25 am »
The padded area is 2 3/8" deep and a little more than 3 1/4" wide (from arc to arc).  There is no real space between the edge of the inner pad and the vertical portion of the holder.  However, the vise grip area is small enough that the whole holder can be positioned a couple inches from the edge of a shelf or table top (meaning the vertical portion of the holder does not need to completely abutt the shelf/top).
R_burke
« Reply #10 on: 25 Mar 2010, 04:00 pm »
Thanks, not sure this will work very well the SA5000s have a real deep band and I'm pretty sure it is greater than 2 3/8" by quite a bit.  I would prefer something that is at least as deep as them, but I will double check measurements tonight.  Again, thanks
TONEPUB
« Reply #11 on: 25 Mar 2010, 04:07 pm »
I use banana hangers from Safeway, $8 each....
Nick77
« Reply #12 on: 25 Mar 2010, 04:55 pm »
$8 at Wally World also.  :green:
R_burke
« Reply #13 on: 25 Mar 2010, 06:15 pm »
All of the bananna hangers that I have seen utilize a "hook" and that would tear the SA5000 mesh band.
I use a bannana hanger for my other sets of phones  :D
BobM
« Reply #14 on: 25 Mar 2010, 06:19 pm »
I use Nipper
