Simple question about speaker gluing, help please.
0 Members and 1 Guest are viewing this topic. Read 1233 times.
Group6
« on: 23 Mar 2010, 03:58 pm »
When we are recessing our tweeters and woofers into our speaker box, what is the best way to secure them? Should we glue or nail them or use something else?
JimJ
  • Ut Prosim
Re: Simple question about speaker gluing, help please.
« Reply #1 on: 23 Mar 2010, 04:34 pm »
I've had good luck with coarse-thread drywall screws, or T-nuts/hurricane nuts and bolts for heavier drivers.
S Clark
« Reply #2 on: 23 Mar 2010, 09:00 pm »
Dry wall screws work great.  It the woofer or tweeter has a foam gasket, it will form an air tight seal.  If not, thin foam weather stripping works well.  I'd avoid something like silicon caulking- after it dries it is nearly impossible to remove the driver from the cabinet should you need to.
