0 Members and 1 Guest are viewing this topic. Read 8913 times.
So now that you have fixed the connections, how does it sound compared to your Emotiva?
I recently just got my first tube gear:
Winter gloves??? Haha, I live in FL. My winter clothing consists of two long sleeve shirts.
Put a couple hundred hours on the tubes and call me in the morning.
Yes "Moron" is reserved for when you blow something up, like a $1500 modified DCX, or try to rewire an amp and when testing whether it works you use a $50 audiophile grade Furutech fuse forgetting that it is installed and blow it because your wiring was not done correctly. Those are moronic moves, and... uhh... I'm just using them as uhhh... random examples... Yeah random examples, not something I have actually done myself.
I recently just got my first tube gear: Mapletree Line 2A SE. I've been comparing it to my previous preamp: Emotiva RSP-1. One thing that really stands out is that the music seems to be within the speakers when listening to the Mapletree. When listening to my SS Emotiva, there is a lot more separation and the music extends beyond the speakers. Is this a common occurrence with tube preamps?
The Mapletree has more dimensionality. It truly feels "live", like the singers and instruments are in the room. Haha, I hate to use the movie Avatar as an analogy (even though I do like it), but comparing the two preamps is like comparing Avatar in 2D and 3D. Both have amazing detail but the Emotiva seems to have everything on the same plane while the Mapletree is fuller and rounder and you just feel like you're apart of everything....
welcome to the wonderful world of tubes! doug s.
