0 Members and 1 Guest are viewing this topic. Read 12404 times.
Treatments and the room makes a HUGE difference. I don't understand "reviewers" that don't have any room treatments (or even room correction, for what it's worth) Paul
I will take a different tack here.Speakers are more important because the best room in the world got no music without speakers. OTOH, you still got music in a lousy room if you got speakers. Having said that, room is a limiting factor on speakers' performance and should be considered in lock step with speakers.
If I only had a choice between getting the speakers or the room "right," it would be an extremely tough decision for me......So, if you only had to chose one, would you focus on the room or the speakers?
What is the context? A dedicated audio room or a shared living space with an audio system?
Speakers -- if your speakers are crap, they're crap. No amount of room treatment will change that.
