BDA-1: Strange problem when in standby mode
0 Members and 1 Guest are viewing this topic. Read 2559 times.
satbox
« on: 21 Feb 2010, 08:17 am »
Hello,
I own a Bryston BDA-1 and I encounter the following strange problem: when it is in standby mode (standby led is lit red), sometimes, the Up-sample led starts to blink for a few seconds. When the Up-sample led starts to blink, sometimes, the standby led also starts to blink...
Do you know this problem? How can I solve it?
Thank you!
« Last Edit: 21 Feb 2010, 02:03 pm by satbox »
alexone
Re: BDA-1: Strange problem when in standby mode
« Reply #1 on: 21 Feb 2010, 09:49 am »
Satbox,
remove the power cable from the BDA and wait a few minutes. it should be ok then. my BDA had the same issue. i guess it's a software thing...
al.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 21 Feb 2010, 12:24 pm »
Hi satbox,
That's a new one on me?  Alex you say it happen to you and you rebooted  - has it happened more than once?
james
alexone
« Reply #3 on: 21 Feb 2010, 08:03 pm »
James,
yes it happened 2 or 3 times. it's gone now... i already sent you an email with a video showing the BDA's usb input blinking red.
al.
alexone
« Reply #4 on: 21 Feb 2010, 09:38 pm »
James,
al.
James,
just to get it right:
the blinking thing appeared when i turned the BDA off. that was 2 or 3 times. after that i unplugged the power cable and the BDA rebooted. the issue was gone then.
al.
satbox
« Reply #5 on: 22 Feb 2010, 05:31 pm »
Hello James,
At my side, the problem arrives almost daily (not at a set time) and the leds blink at an irregular frequency during 1 or 2 minutes.
At your opinion, is it hardware or software? Let me know if you want that I test something to help you...
Thank you!
« Reply #6 on: 22 Feb 2010, 06:01 pm »
Hello James,
Thank you!
Hi satbox,
I took this to engineering but so far blank stares - we will continue to think about what it could be.  You can certainly load new sofware and see if that solves it.
james
satbox
« Reply #7 on: 22 Feb 2010, 07:42 pm »
OK, thank you for your quick feedback!
If you want that I load a new software, let me know and send it to me.
« Reply #8 on: 22 Feb 2010, 07:46 pm »
Ok email me at [email protected] and I will send it.
james
« Reply #9 on: 22 Feb 2010, 08:01 pm »
james
Your email keeps bouncing back the executable file.
james
srb
« Reply #10 on: 22 Feb 2010, 08:12 pm »
James,
Although it could be an email client setting, some email servers are setup not to accept executable files.  You could try to zip it first.
« Reply #11 on: 22 Feb 2010, 08:30 pm »
James,
Thanks Steve - got it to go through on a different email address.
james
