0 Members and 1 Guest are viewing this topic. Read 14107 times.
DIY...DIY...http://planet10-hifi.com/boxes-fostex.html#fonken
Tuff finding a lot of highly efficient speakers that are bookshelves, Robert...without going to single driver units (with or without additional supertweeters)Small drivers are less efficient, generally speaking If you don't like single drivers (I've yet to hear a pair that I wanted to own, but that's me), then find a pair of bookshelves with minimal crossover network. They'll be a lot less lost on the way to your ears with minimal crossovers.Have you considered active speakers? It's a good way to go and there are some very fairly priced units on the market these days.I owned the passive Quad 11L's and thought they were terrific value.....the 11's and 12's now come active and occasionally sell for your price range used. Here's one, brand new, for more than you want to spend: http://www.audiogon.com/cgi-bin/cls.pl?spkrmoni&1270345379&/Quad-12L-Active-monitors-New-bIndependent 60watt amps and individual volume controls. It's a great way to enjoy elevated SPL's with very little compression in sonics. In other words, they are bookshelves without sounding like them. There are others, too (Paradigm comes to mind) that may prove suitable, too John
Robert, If you type in Quad in the search box at Audiogon and scurry thru to the speaker selection there, you'll see that a (active) Quad 12L just sold for $575 from a very reputable dealer in Portland, EchoHiFi.com (nee, Echo Audio)So, they're in your price range used (<$600), but not new.You can find venerable Mackie 824 actives around for $600 used sometimes.Right now on Audiogon there are Quad 9's, which only have 4" woofers so even active they may sound a bit tepid if you're room is at least average sized, for $539.00 http://www.audiogon.com/cgi-bin/cls.pl?spkrmoni&1269024442&/Quad-9L-active-near-new-and-nibtw, the finish on these Quads are simply masterful....on finish alone you'd swear they would cost far more than they do.As the speakers also incorporate the amplification stage, adding them is simplicity itself (and merits inclusion in Cheap & Cheerful Circle because of it )Here's another way to go (92db efficient) that I have been thinking about myself for a second system paired to old 10 watt mono tube integrated amps I have...from HSU Research and well under your budget: http://www.hsuresearch.com/products/hb-1.htmlRegards, John
John, thanks for your advise. I've been looking at HSU speakers for a bit they ONLY reservation that I have is that tweeter design. Metal dome tweeters to my ears sound to damn bright. Yes they do offer a return policy but it would be just a hassle to order them, try them and pay for shipping both ways I will look further into your selection advise. This is for a second room setup to be honest and I am running a 10 wpc amp as well
