What is Maximum Length of Microphone Cable in Audio Studio Setting
0 Members and 1 Guest are viewing this topic. Read 3199 times.
marsx
Hi,
I've read on various forums that the length of cable from your mic to audio card should be no longer than 20 feet or the signal will start to degrade or have a higher chance of receiving interference.  First, is this true?  Second, if it is, are you talking about the distance of the cable from the mic to the preamp, or the distance of the whole signal chain (mic to preamp to any outboard gear like a compressor, and then to the audio card).
If it is just the distance to the preamp, is there a rule of thumb on what the total distance should be from the mic to the preamp, and outboard gear and then to the audio card, before degradation of the signal occurs?  This is, of course assuming I am using high end Mogami or Monster cable and all the equipment is balanced.
Any responses would be greatly appreciated.
Sincerely,
marsx
NagysAudio
    • http://www.nagysaudio.com
First, what length do you need? Second, most well designed cables should have no problem at 20 foot lengths. But it's hard to answer your question because it depends on a lot of variables. The AWG of the conductors, how well it's shielded and what type of shield it uses, is there a lot of EMI, or RFI interference in your area, etc.
I design my balanced cables using a very high quality military 2 conductor coax cable. It's high purity copper, silver plated and Teflon insulated, with silver plated Neutrik connectors. I've supplied recording studios in the past. Send me a PM if interested.
Norbert
