0 Members and 1 Guest are viewing this topic. Read 3314 times.
In sound reinforcement, runs exceeding 200 ft are common. There are many other more important variables like the quality of the preamps & mics. The entire world does not possess the audiophile fetish for cables.
Hi,I have read that the signal from a microphone degrades after about 20 feet on various forums. When people say this are they refering to the whole microphone signal chain (mic to preamp to audio card) or are they just talking about the distance from the mic to the preamp?Secondly, if it is just to the preamp, is there a rule of thumb in the studio about how long the whole signal chain can be from mic to preamp to audio card before degradation or interference may cause a problem. This is assuming all cable is high end Mogami cable and all equipment in chain is balanced. Any responses will be greatly appreciated.Sincerely,marsx
Perhaps that is a symptom of why there are so many 'average' recordings of great music??
The reason is average engineers compensating for mediocre talent.
A high output impedance mic is also more prone to pick-up RFI. I have personally experienced this with just 10 and 15 foot lenghts of Nogami Gold XLR cables going into a high impedance input of my microphone pre-amp. I think my home studio is some weird RFI magnet, however. . . as I also pick up RFI with my bass guitar directly into a computer interface and with 2 different electric guitars through my pedal board. Same radio station every time. Paul
Sounds more like a grounding/shielding problem to me.Regards; Dan Banquer
I have thought the same thing, but it does happen with totally different equipment. I have tested the ground on the outlets and the little tester indicates they are all properly grounded. I have used different cables. They are all (supposedly) well made, shielded and highly regarded. (Nogami XLRs and DiMarzio guitar cables / patch cables) Any ideas? Please post them here: http://www.audiocircle.com/index.php?topic=72447.20Don't mean to hijack this thread. . . regardless of my problems, I have read high impedance microphones are more prone to RFI. Thanks,Paul
Sorry, I should have been more specific: Check the grounding inside the microphone and mic pre amp.Regards; Dan Banquer
"Thanks. The microphone RFI is minimal and is only noticeable if I crank the adjustable impedance adjustment on the pre-amp input fairly high. Happens with 2 different mics; 3 different cables; and 2 different pre-amps, so I would think that would rule out any wiring / grounding issues. I can also move the cable to certain spots to avoid it when it does happen."I was referring to the grounding inside the microphon(s) (especially the microphone) and mic pre amp(s). Again I shlould apologize for not being more specific.To sum it up, you shouldn't be getting any RF pick up if the equipment is grounded correctly internally.Regards; Dan Banquer
