Question about Cable Length for Microphones in Audio Studio Setting
0 Members and 1 Guest are viewing this topic. Read 3316 times.
tvyankee
what r the mic pre's  feeding into?  If you can take the mic pre directly out into like a speaker box like a qbox and listen to it direct and see what you get. also unplug what you are feeding the mic pre and listen to just the output of the mic pre. see what you get then and then start plugging stuff in.
Dan Banquer
An excellent suggestion to help isolate the problem.
d.b.
