0 Members and 1 Guest are viewing this topic. Read 21690 times.
My wager is that the internal loading of 500K is way too high for a typical MC.
Then add load resistors in parallel to get to what the proper loading should be for your cartridge.
Open it up and find out what's inside. You should be able to spot the input loading resistors right away. I read the owners manual for the Cotter PSC-2 (assuming that this is what you might have) and it explains the internal loading of 500K. It is to match the MC step up transformers' secondaries. The MC step up transformers' primaries are usually of a lower impedance that will match the MC cartridge more closely.The question now is what setup are you using? MM or MC?
Most cartridges MM and MC have a recommended resistance and capacitance to be inline with them before the phono preamp, usually in parallel. How does the R value alter the sound as opposed to the C value. In other words, what should one experience as the two values are adjusted up and down away from their recommended values with regards to a MM cartridge?
You can't measure all phono stage's impedance by measuring DC resistance. It depends on the circuit topology.
If your Cotter is loaded at 500 K ohm then either cartridge would sound pretty hot and bright (not in a good way) in the top end and could drive your preamp into clipping during loud passages.I'd experiment with lower loading values and evaluate the sound.
You may find this looong thread intersting reading.http://www.vinylengine.com/phpBB2/viewtopic.php?t=6674&highlight=catridge+loadingJames
