0 Members and 1 Guest are viewing this topic. Read 21723 times.
Hey! Soldering on resistors at your cartridge headshell sounds pretty bizarre and an excellent way to get into trouble! If you're going to use resistors just plug your TT leads into F-adapters (much neater than the T-adapters you usually see), and then make up plugs of different values you can plug into the 2nd leg of the adapter.
I use plug in resistors.
Where do you get these? Are they just RCA plugs with resistors in-series?
Cartridge loading changes with VTA. Interesting, but I'd have to say that I too disagree. I can't live without VTA on the fly. It varies from record to record. To me it's much more than relative bass output or sparkle up top. The harmonics change and you can hear when it's dialed in. I don't change it for every record though. Getting the preferred load for a cartridge is kind of similar, but VTA changes will still be necessary. If you use the M97 as an example, it sounds laid back, mellow at 47K. At 62K the high end is around the same as 1K and below, and the lower treble dip isn't as pronounced. That is, as long as the total capacitance is low. That's in general, not specific to a record.
