Ceilume - anybody used these?
0 Members and 1 Guest are viewing this topic. Read 1523 times.
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« on: 16 Feb 2010, 06:48 pm »
Hey guys, I'm finishing off a 23x13x8 space in the basement as a dedicated room.  Just wondering if anybody has ever used the Ceilume ceiling tiles instead of a traditional drop ceiling.  If so, what do you think of them?
I'd think they would work very well acoustically speaking.  The thin vinyl should pass frequencies below 500hz or so into the fiberglass that'll be behind them, and certain shapes look as though they would function somewhat as diffusers at frequencies above that.
http://www.ceilume.com
The other thing I'm planning is to use GP Yellowboard panels instead of traditional drywall or Greenboard panels.  It is a basement and can get moist, the yellowboard is made for moisture resistance ... but should have the added benefit of being excellent for acoustics.  Home Depot here just started carrying Yellowboard.
http://www.gp.com/build/Product.aspx?pid=4659
Ethan Winer
  • Audio expert
Re: Ceilume - anybody used these?
« Reply #1 on: 17 Feb 2010, 01:42 pm »
Diffusion requires depth, so tiles with a thin "relief" pattern will not do what you hope. The patterns would have to be at least a few inches deep to be useful at audio frequencies.
--Ethan
Vapor Audio
    • Vapor Audio
« Reply #2 on: 17 Feb 2010, 11:25 pm »
--Ethan
I realize that ... if they have 3 inches of relief they'd provide diffusion down to around 2250hz, which is more than a flat painted ceiling would.  I was more interested in the product itself, if anybody here had used it and what they thought if so.
