KEF Reference 207/2
0 Members and 1 Guest are viewing this topic. Read 32024 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: KEF Reference 207/2
« Reply #40 on: 24 Feb 2010, 10:11 pm »
James,
Isn't the coincidental arrangement of the tweeter and midrange driver a Jim Thiel invention?  I seem to remember that he pioneered that concept but could be wrong.  I know that the great soundstage you are hearing is a Thiel hallmark.
Bill
Hi Bill,
I know Jim Thiel worked with it for many years but I do not think he invented it.  KEF has also used it for many years and Tannoy forever.
james
SHV
« Reply #41 on: 24 Feb 2010, 11:13 pm »
If anyone "invented" it was probably Tannoy.  Bozak (remember them???) also had several models that had a "Tannoy" type of arrangement.
gtaphile
« Reply #42 on: 25 Feb 2010, 01:28 pm »
Not sure about coincident drive arrangements but I believe Altec introduced the first coaxial in the 604 arangement in 1943.
VOLKS
« Reply #43 on: 25 Feb 2010, 03:59 pm »
James...........whats your opinion of them so far?
« Reply #44 on: 25 Feb 2010, 04:31 pm »
Great sound stage , huge dynamic capability, very efficient, takes soft to loud differences in dynamic levels in stride, presents a more distant sound stage than say the Thiels.
James
P.S.
These are the very pair that John Atkinson reviewed in Stereophile.
P.P.S.
Oh - and they weigh a TON!
SHV
« Reply #45 on: 25 Feb 2010, 09:23 pm »
Then Altec 604 from 1943 is the earliest commercial "coax" that I could find....the Tannoy "Dual Concentric" coax was introduced in 1946.
HsvHeelFan
« Reply #46 on: 8 Mar 2010, 05:36 pm »
James
P.S.
P.P.S.
James,  can you clarify the "more distant soundstage" comment compared to Thiels?
Do you mean that you're sitting farther back in the concert hall or something else?
With my KEF Q70's, the soundstage is "right there" in the room with you.  Most people would probably say that my KEFs are a bit "forward".
HsvHeelFan
« Reply #47 on: 8 Mar 2010, 05:44 pm »
Hi,
Yes I meant I feel as if the soundstage moved a little further back from me when listening to the KEF's as compared to the Thiels. I assume it has to do with the difference in polar response and dispersion characteristics of the given speakers.
james
Sasha
« Reply #48 on: 10 Mar 2010, 04:37 pm »
Hi,
james
James,
How do in your opinion polar response and dispersion characteristics affect perceived soundstage distance?
« Reply #49 on: 10 Mar 2010, 05:08 pm »
James,
Hi Sasha,
I find depending on the early reflection characteristics of a given speaker it tends to move the apparent soundstage forward or back.  For instance I now have the Roger Sanders speakers set up in the same room and being a dipole the sound stage starts at the speaker and moves backwards.  With the Thiel in the same position the soundstage projects forward from the speakers.
I am assuming that some of the early reflections and wider dispersion pattern in the Thiels is the reason for this affect in my room?
james
vegasdave
« Reply #50 on: 13 Mar 2010, 12:48 am »
Hey James, are those 2 12s on the KEF References?
« Reply #51 on: 13 Mar 2010, 02:22 am »
Model Model 207/2
Design Bass reflex four-way floorstanding loudspeaker, magnetically shielded
Drive Units 2 x 250mm (10in.) LF, 1 x 250mm (10in.) LMF, 1 x 165mm (6.5in.) Uni-Q MF including a 25mm (1in.) titanium HF
Crossover Frequencies 120 Hz, 350 Hz, 2.3 kHz
Sensitivity (2.83V/1m) 91dB
Frequency Response (+/-3dB) 40Hz - 60kHz
Maximum Output 117dB
Amplifier Requirements 50 - 400 W
Magnetic Shielding Yes
Impedance 8 Ohms (3.0 Ohms min)
Bass Extension 26Hz (-6dB)
Weight 66 Kg (145 lbs)
Dimensions (H x W x D) 1226 x 400 x 685 mm (48.2 x 15.7 x 27 in.)
Finishes Piano Black, High Gloss American Walnut, High Gloss Cherry, Satin Black, Satin American Walnut, Satin Cherry and Satin Sycamore real wood veneers
vegasdave
« Reply #52 on: 14 Mar 2010, 06:41 am »
Do those 10s kick pretty good?
« Reply #53 on: 14 Mar 2010, 12:26 pm »
Hi Dave,
Yes they are very good - tight and deep with excellent control.
I know where your coming from though - I have a friend - (big JBL Fan)- who says "if its smaller than a 15 inch it's a tweeter" :icon_lol:
james
Laundrew
« Reply #54 on: 14 Mar 2010, 03:16 pm »
Hi Dave,
james
I have heard this somewhere before :scratch:
Be well...
« Reply #55 on: 14 Mar 2010, 03:23 pm »
Be well...
Ron at Altronics :D
james
Laundrew
« Reply #56 on: 14 Mar 2010, 05:13 pm »
Ron at Altronics :D
james
 :D :wink:
Be well...
Napalm
« Reply #57 on: 14 Mar 2010, 05:24 pm »
Mhhh looks like KEF are now specialists in the aesthetics of ugliness...
Nap.  :o
vegasdave
« Reply #58 on: 14 Mar 2010, 06:48 pm »
Hi Dave,
james
Cool, and exactly. As you told me before, big woofers are not a problem to drive with your amps.
V
« Reply #59 on: 24 Jun 2010, 09:16 pm »
james
The Montana Master Reference speakers have each two 18" inch woofers.
