Anyone offering flat packs for the N3 or NX2?
0 Members and 1 Guest are viewing this topic. Read 7966 times.
motosapien
« on: 7 Feb 2010, 04:05 pm »
I'm out on the left coast for the time being and far away from my woodworking tools.  I'm looking for a flat pack with the holes routed and the baffle edges rounded.
« Last Edit: 8 Feb 2010, 11:23 pm by motosapien »
Danny Richie
Re: Anyone offering flat packs for the N3?
« Reply #1 on: 7 Feb 2010, 11:09 pm »
Let me see what I can find for you.
motosapien
« Reply #2 on: 8 Feb 2010, 02:51 am »
 :thumb:  - With any luck I can achieve "flush & square" and apply a basic, paintable veneer to the sides & top.
But to tell you the truth, even if I can't find precision manufactured wood parts, I could do it with the my hand tools and be happy with a rattle can finish if the sound is right.
matt34
« Reply #3 on: 8 Feb 2010, 06:17 am »
Send the plans to Elemental Designs and they will give you a reasonable quote.  I did it for a pair of statement-minis(floorstanders) and it was $275.
motosapien
« Reply #4 on: 8 Feb 2010, 01:14 pm »
One thing I could also do is check out local cabinet makers.  Takes some leg work but I might find someone who is "interested" in the project as we say.   Well, I decided to go with the NX2.  Sorry to change horses midstream Danny.
I am excited about this project.  The larger woofer kind of sold me on the NX2 along with the ribbon tweet and sealed box.  I am expecting a major improvement over my entry level Epos ELS8's.
« Last Edit: 8 Feb 2010, 02:22 pm by motosapien »
wgallupe
« Reply #5 on: 8 Feb 2010, 07:13 pm »
Danny,
Even though Motosapien has decided to go with the N2X, I'd still like to hear what you find out about flat packs for the N3 and possibly the OB5. I would also be interested in getting quotes for built & veneered but unfinished cabinets for both the N3 and OB5. Is there a list of trusted sources?
Wayne
chip
« Reply #6 on: 8 Feb 2010, 11:06 pm »
There is some info here -
http://www.audiocircle.com/index.php?topic=71795.0
I know chris mentioned that he is on hold doing them for a while but you can check with Elemental Designs.
Danny Richie
« Reply #7 on: 8 Feb 2010, 11:09 pm »
I might have a flat pack for the N3 here next week. I'll post something when I get it here.
wgallupe
« Reply #8 on: 10 Feb 2010, 12:57 am »
Great. Looking forward to your post.
Danny Richie
Re: Anyone offering flat packs for the N3 or NX2?
« Reply #9 on: 10 Feb 2010, 01:08 am »
The owner of the flat pack can't get it out yet because of the snow... Dang global warming.  :duh:  I'll keep you posted.
Christof
« Reply #10 on: 10 Feb 2010, 02:03 am »
What happened to 33 Degrees East WoodWorking....wasn't he (Chris?) offering CNC flat packs for next to nothing ???
dvenardos
« Reply #11 on: 10 Feb 2010, 10:02 am »
http://www.audiocircle.com/index.php?topic=73310
motosapien
« Reply #12 on: 14 Feb 2010, 09:52 pm »
Bought two 2' x 4' x 3/4" MDF at Home Depot and stopped by a cabinet maker with the cut sheet.  Half hour later I had precision cut pieces and had made some new friends.  The guy who owned the shop had made speaker cabinets, thousands of them, back in the day which I assume was the seventies/eighties.  They charged me $20.
I was able to build the cabinets minus the front & backs with a couple 24" clamps.  They are damn near perfect as far as flush and square.  I now have to decide if I want to invest in router (any recommendations?) or just have my buddies at the cabinet shop do it.  I also need to install the internal braces but I want to do this as I add the no-res material.
And yes, I should have photographed and posted my kitchen table clamping setup.  It just worked so slick.
Danny Richie
« Reply #13 on: 14 Feb 2010, 10:08 pm »
You can get a router from Sears and a Jasper Jig from parts express for under $100 last I looked, but it's been a while.
I'd go ahead and install all of the braces then the No Rez. Just leave the front baffle for last.
Zerogravity
« Reply #14 on: 21 Feb 2010, 11:18 pm »
eD just e-mailed me a few weeks ago stating that they could produce a complete kit with driver cut outs and everything for mid $200. I am still thinking very hard about this!
srclose
« Reply #15 on: 22 Feb 2010, 01:26 am »
Hi,
A friend of mine is offering these N2X cabinets, he can be contacted at "[email protected]" with the following prices."
Flat pack- $125.
Assembled, unfinished- $175.
Finished- $265.
White Oak or Maple Veneer 3/4" MDF
prices do not include shipping.
Stephen
Zerogravity
« Reply #16 on: 22 Feb 2010, 09:15 pm »
Thanks for the tip Stephan. I inquired about a Ported N3 build. Since I sit a fair distance away and space is little tight, Danny has recommended these over his other designs. I have never listened to the Neo3 tweet before. I recently purchased a new pair of SLS H.T. 6.5s monitors that use the Neo3 and it sounds fantastic. The low end reaches to 40Hz, as it is a ported design, although not up to the specs of the N2x, as it could benefit from no-rez instead of the standard pollyfill. It could also use some bracing although I'm  not sure if it will effect the crossover design.
Danny Richie
« Reply #17 on: 22 Feb 2010, 09:26 pm »
Ruben is looking for cabinet building work. He posted some pics in this thread:
http://www.audiocircle.com/index.php?topic=77348.20
He even mentioned that he'd build and ship COD.
You guys might want to see what he will do for you.
Zerogravity
« Reply #18 on: 23 Feb 2010, 02:02 am »
I appreciate it Danny, I will check it out!
