0 Members and 1 Guest are viewing this topic. Read 33961 times.
"Sorry, the page (or document) you have requested is not available.Please check the address and try again."Can't view it....
Rachel - you note to estimate the cost of shipping at $1/lb. but the sheet is in kilograms. For those of you who need to know the conversion its 1kg = 2.2 pounds so something that is 127 kg volume weight is in fact 279.4 pounds or about $279 to ship.
Regretfully I must withdraw from the group buy as the racks offered do not provide the space I need.Thank you for the offer.Jake
Nice looking racks at decent prices. It's too bad the upper shelves on 3 and 4 shelf racks don't have more headroom. 6 inches just doesn't cut it for most guys.
The width and depth of the Nobility stuff looks fine, but I think the height dimensions will make it unsuitable for many who otherwise would be interested -- particularly for guys with tubed gear where breathing room is essential.
I have fixed height shelves with 9-1/4" clearance. I've had to pass on some solid state gear (not Class A) that was 7" - 8" high and the manufacturer had recommended 3" - 4" clearance height above it. Steve
I see. Most Chinese audiophile put their tube gear on separate amp tables (like SRW-1A) on the floor so the furniture manufacturer is not considering the headroom for heat in multiple racks.
If you need specific spacing between the shelves, let me know then I will see if factory can custom make for you. If you are looking at a simple shelf - custom order should not be too difficult.
